MetroFi 220 or CX300-II?
18 Oct 2002
Lo all,
I'm in need of some new in-ear headphones (on a 'under £50' budget) and I think I've got it down to one of these two.
They will be mostly used for running (hence the budget - I don't want to get all sweaty over expensive 'phones). However, I'm flying to America on Friday and I want something that's going to provide a bit of noise isolation against the hum of the aircraft.
UE say that the MetroFi 220's provide 16db of noise isolation which isn't much. I can't find any stats for the CX300-II's.
Which would you recommend?
Cheers,
Panzer
I bought the CX-300-II's in the end.
They were cheaper and I've decided I'm going to try and find a pair of UE TrippleFi 10's in the states.
Panzer
