Metros/Hairdressers.
Mic
Mic
4 Aug 2005
Ireland
Need some advice/help on hair
I usually get a size 3 razor on the sides, but its a bit too short for my liking. Im contemplating getting a six, but i dont know how long a 6 is.
Can anyone help?
Pictures of a 6 on the sides would be very helpful.
Bit like that i recon ;)
Only kidding mate. A grade 6 might be a bit long though?! What you planning on doing with the rest of ya hair?
Just shortening it back really.
I just get a 3 on the sides and a 'good bit' off the top.
3 seems short to me, not sure about 4 and i dont think there is a 5.
chippie said:
Not a metro or a hairdresser, but I do have some clippers. The No.6 guard is 19mm, which is TooLong™. You need a No.1.
Hell NO!
Thanks both you and Pezboy, anyone have a picture of a 6 on the sides? Give me a better idea
