MF and AF
16 Sep 2005
What used to be a UK
Understandably some or all modern dslr's have AF & MF on the body of the camera, but why do they also have that function on the associated lense? Sorry if this is an idiotic question.
Makes changing settings faster. At least that's what I felt back then when I used my Canon 20D. i.e. when shooting AF, and I suddenly want to MF, just push the tab and MF away.
So does changing the focus from the lense overide the settings/button used on the camera body? Thank you.
Aye. The hardware button overrides the settings on the camera body. At least that's what happens on the Canon and even on my Olympus when I used the Sigma 30mm.
Cool. I've only just received this (Alpha 550) and I couldn't recall there being AF and MF on the ealier models kit lense (A100, for example). Thank you for the answer.
It's because the switch physically disengages the AF motor allowing you to twist the ring. On most cheaper/kit lenses you cant twist the focus ring while the switch is in "A" position. The in-camera setting just disables the AF through "software".
You can still manually focus on lenses which have a manual override focus though.
That lens has a built in motor. As with any Sony lens with "SAM" in it's name... not sure what it stands for, but I think it's a small low power motor. Anyway, the AF/MF switch on the lens engages or disengages this motor. The AF/MF switch on the camera will have no effect on the lens operation.
Just to confuse matters even more you can get lenses with full time manual focus (or thats what its called for Canon - not sure if its a generic term!) which means that even when its in AF mode you can still turn the focus ring as if its in MF.
Same on Nikon, it's M/A instead of just A.
As do Sony, my 70-300G has a feature called "Direct Manual Focus (DMF)" which works when you are in AF-A or AF-S... not AF-C though...
Olympus E-Systems have the 'Fly-by-Wire' setup for all of it's lenses, which only focus when the body is turned on, all AF/MF is selected in body. Only a handful of which actually has a mechanically-coupled manual focus ring, much like FTM focus.
