After some great advice on here (and a bad journey trying to get my d2 working in win7) i bought a hifidiy aune dacamp and some dr150s.
The problem i have is my onboard sound is basically knackerd. it constantly throws up a dialog asking what i have plugged in etc. The same setup was fine with the d2 and ive changed the mic cable twice.
Can you spec me a cheap usb soundcard or pci soundcard for mic use?
Cheaper the better
Cheaper the better
