Micro ATX case with good airflow - mesh front
15 Jul 2008
Hi All,
I'm looking for a replacement case, I currently have a Thermaltake Versa H18 Tempered Glass but managed to break the glass panel a while back, after 2+ months of trying to source a new replacement side panel from Thermaltake who now have stopped replying to any emails (seemed to be going well for a replacement at the start).
So that leads me onto needing a new MATX case, with at least good airflow so a mesh style front would be ideal. Also it ideally would take 140mm front/top fans (as I have my own I want to use, so doesn't need to have many/any included) and be able to take a big/tall CPU cooler (Dark Rock Pro 4) preferably with no RGB.
I was looking at the Fractal Meshify Mini but the prices seem to have shot recently (with everything else) and would prefer to spend a little less.
The Thermaltake S100 TG looks great for the money though not sure what the airflow would be like with only thin strips down the side of the front panel.
So any recommended MATX cases that fit the bill welcomed.
Many Thanks
Maybe something like the Phanteks P300A could be an option? Supports 140mm front/top fans and has a mesh front.
The Dark Rock Pro 4 height is 162.8mm and the max supported for the P300A is 165mm, so that might be the only thing a bit tight.
The P300A is fricking tiny. I’ve had to swap it for a P400A to have enough space for an RX 580 and a custom water loop.
