Hi all,
I'm looking into building a small machine that won't be used for much other than gaming, the less I spend the better, but consider £900 the absolute limit.
The spec:
CPU: i5 3570k - £180
Mobo: ASUS Maximus V Gene - £155
GFX: MSI ATI 7850 Twin Frozr IV - £175
RAM: 8GB Corsair Vengeance LP 1600mhz - £45
HDD: Samsung Spinpoint F3 1TB - £68
SSD: Samsung 830 128GB - £90
Case: Fractal Design Define Mini - £75
That leaves me needing a PSU, mouse, keyboard, OS, CPU cooler, and anything else I might have forgotten.
Other thoughts:
I'll be looking to overclock a bit, but I won't be looking to go crossfire/sli in future. (I'm guessing some of you may suggest a cheaper mobo.)
PSU-wise I'm not too knowledgable, other than that I will want a modular one.
CPU cooler will need to fit inside the case!
No need for a disk drive at this point as I'll be installing the OS by USB.
Suggestions welcome!
The spec:
Other thoughts:
