Hi guys,
I am looking to upgrade from the spec in my sig apart from my graphics card, but my primary requirements are that I can transport my rig easily (I go to LANs a lot), and that the machine is as quiet as possible. I also want an SSD for the OS and games, my other files are on a central file server.
My budget is 600, however if watercooling is a recommended option to keep it quiet I'm willing to spend a bit more, however I'm not that fussed about overclocking. I've already got a general idea of some of the parts (e.g. i5 2500K and Crucial M4 SSD) but I'm not sure about the other parts.
EDIT: I should also clarify as well:
* I have an external DVD drive which I will use for installing etc. (who uses discs these days anyway?
* The PSU in my current machine is on its way out (fan has stopped and is out of warranty).
* I have a 500Gb drive I can use as a secondary / data drive.
* I have Win 7 Home Professional on there now (yes I need to update my sig).
Thanks in advance
)* The PSU in my current machine is on its way out (fan has stopped and is out of warranty).
Thanks in advance
