Hello overclockers forum, I am looking to build a micro atx rig but im not to sure of the components that I want, I would like the build to be based around the case (Corsair Carbide Series Air 240 High Airflow)
I have a budget of around £500 but this is complimented by the fact that I already have a Hard drive and Ram that is still up to date that I could salvage from my Current rig, My Current specs are (i5 2500k , Nvidia 560ti)
I am not sure if it is worth upgrading my i5,2500k to the newer I5's as I have not overclocked it and I am mainly bottlenecked by my GPU.
If anybody could help me build a new rig for around the £500 price tag that would be great, These are my old specs in full
Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
GeForce GTX 560 Ti
Kingston Genesis 8GB 1600MHZ
1TB Storage- an SSD wuld be great
ASUS p6p87 le
If reusing the i5 - 2500k is the best option to keep the upgrade under £500 then that is fine, If you could find a newer board that would run it and allow me to overclock it using the Corsair H100i that would be great,
Many thanks
GeForce GTX 560 Ti
ASUS p6p87 le
Many thanks
