Micro ATX Server Case
20 Feb 2004
Hondon de las Nieves, Spain
About a year ago i built a server using the Lian Li V351. The space I had available was a shelf that was only about 32cm deep so the fact this could be used “sideways” appealed a lot. It also looks pretty fantastic.
Unfortunately what I didn’t think about was the fact that despite the fact its huge, it only has space for 2 3.5” HD’s (3 with converting a 5.25” bay). As such the time has come I need to add extra space and I’ve hit a wall and need to invest in a new case with plenty of hard drive space.
Ignoring minimum depth now as I’ll just stick it on the floor (or put the case sideways again depending on height)
On my list therefore are
Fractal Designs Arc Mini
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-FD&groupid=2362&catid=2278&subcat
Seems fairly well laid out and space for 6 hard drives and pretty reasonably priced at £70
Fractal Design Define
Pretty much as above as far as I can tell, only with a covering door to make it look a little better.
Lian Li V354
http://www.overclockers.co.uk/showproduct.php?prodid=CA-239-LL&groupid=2362&catid=2278&subcat
Lovely looking and seems a little smaller than the Fractal cases which looks a bit better, especially as its out on show. Space for 7 HD’s. Downsides are that at £145 its very expensive!!
Silverstone[ PS07
http://www.silverstonetek.com/product.php?pid=314&area=en
Looks great in white and gives me what I need, although the internal layout perhaps isn’t quite as good as the others for accessing the hard drives.
Does anyone have any suggestions or comments for the above?
The other thing i've been looking for is that since i use a Pico PSU i always end up with a huge PSU sized hole in the back of my case. Does anyone know of anywhere that sell a cover plate?
Cheers for that.
Remembered my motherboard is actually a Mini-ITX version so now i've currently got my eye on the Bitfenix Prodigy. It seems small and has space for 5 HD's which is plenty for me.
Either that or the Lian Li Q08 also seems decent, and more logical that the V354.
Had a look at the tiny little Fractal Design Array but the reviews are dreadful!
Never seen a PSU cover to block off an ATX hole but as the screws are always in the same place if you've got a dremel you could make one... make it out of alu and then a green scouring pad will let you 'brush' the finish.. once you've got it just swap it between cases.. failing that, get one made.. there are still little engineering works that'll do one offs
