Micro-ATX System Upgrade
8 Jan 2005
Looking at updating the system in my sig, used for gaming and general PC work. As you can see from my current spec I prefer value over performance :) and I'm prepared to O/C it some.
Anyway the budget was meant to be £400, this is somewhat over - is this good value and well-matched? (I'll be using most of the other bits from my sig in a different machine). Is it worth going from a E7300 to a G6950?
Thanks for any advice.
An overclocked e7300 still does pretty well and the upgrade to the G6950 wouldn't be particularly noticeable. Upgrade the graphics card and stick with that until socket 1155 comes out next year tbh.
