Quite a few should as the Titan is only 267mm in length meaning it is shorter than a 690.
My Lian Li V355 takes cards upto 310mm.
Just check the specs of the case your interested in and it will tell you what the support is for cards.
and the 350d
How is the noise in the PC-V355?
Well mine is the noise dampened version so comes with better sound proofing which would make a bit of a difference.
Can't comment on what it would be like normally.
