Micro SD Question
14 Nov 2012
Chesterfield
Not sure if this would call under Storage, Memory or Tablets, but here goes.
I have an 8gb Micro SD card being used in a Nabi 2. My autistic son-in-law has a habit of inadvertently removing files from the memory card.
I know you can lock SD Cards, but is there a way of locking the Micro SD to stop items being deleted or changed, while still allowing access to view the contents?
After a quick search on google I found the following (not sure how well it will work):
http://anwarayblogger.blogspot.co.uk/2011/04/how-to-enabledisable-write-protect-in.html
1. To disable write protection [so that you can copy mp3 songs from pc to micro sd]
Right-click on a file if there is just one specific file you want to disable write protection for. Or right click on a folder if you wan to disable all its content. Click on the "Properties" link from the menu that will pop up. Navigate to the "General" tab. Click or Unchecked on the box marked as "Read Only" and then close the Properties window.
2. To enable write protection [so that you can't copy files from pc to micro sd]
Right-click on a file if there is just one specific file you want to enable write protection for. Or right click on a folder if you wan to enable all its content. Click on the "Properties" link from the menu that will pop up. Navigate to the "General" tab. Click or checked on the box marked as "Read Only" and then close the Properties window.
The read-only setting may not matter to your Nabi 2, worth a try though I guess.
