Micro SDHC Adapter Question
18 Oct 2002
Sunderland
Not sure if this is the best place for this, but couldn't really decide where to post it.
I recently bought an 8GB micro SDHC card for use with a couple of things, and am getting a new camera soon that I have just found out supports SDHC. The card came with a USB adapter, but no micro SDHC -> standard SD adapter.
I have numerous micro SD -> standard SD adapters lying around, will these work correctly for a micro SDHC card or do I need a special one?
I'm guessing I could just try it, but I wanted to be sure before I take the card away with me on holiday just in case I hit a problem after a certain amount of the card is used.
Suppose I could just try copying 8GB worth of data on via the PC?
Edit -AM thinking that last suggestion won't work as my SD card reader probably doesn't support SDHC?
yup will work just fine my 4gb micro sdhc card that i use in my phone works fine in my nikon d80 with the adapter :D
