What is it and when does it appear.
Microstutter: What it is and how to fix it | PC Gamer
"Have you ever noticed unexpected choppiness in a game where framerates and performance otherwise seem fine? This can manifest in many ways, and benchmarks don't always tell the whole story (which is why my tests included a 97 percentile minimum fps). Most recently, I was testing The Crew 2, a game with a hard 60fps framerate cap, and short, irregular frame dips—often referred to as microstutter—are definitely present.
There are multiple potential causes for microstutter, with possible solutions that may or may not work. But let's start by first explaining microstutter.
Let me first explain that microstutter isn't the same as the stutter associated with low framerates, or in some cases massive dips in performance while a game loads new assets. (Kingdom Come: Deliverance had severe stuttering at launch, mostly due to loading new textures and models for a complex environment.) Microstutter is more subtle and often harder to measure objectively—the best tools like Nvidia's FCAT involve color tagging of each frame received by a high-end capture card.
Blur Busters has a great webpage that can help you see microstutter in action. If you swap between the 'smooth' and 'microstutter' options, it's immediately obvious which one is better—and if you have a monitor with a high refresh rate, the test supports that as well. Microstutter most often occurs when the rate of new frames doesn't quite match up to your monitor's refresh rate and vsync is enabled."
Users all over the internet report cases of micro-stutter.
Microstutter in all games (every few | NVIDIA GeForce Forums
MICROSTUTTERING in Games on POWERFULL PC - Troubleshooting - Linus Tech Tips
How Do I Fix Stuttering in My Games | HP® Tech Takes
How to Fix Micro Stuttering in Games on Windows 10 | Driver Talent (drivethelife.com)
[SOLVED] - Micro-stuttering in most of my games ? | Tom's Hardware Forum (tomshardware.com)
I have seen micro-stutter on quad-core setups as well: Core 2 Quad and Ryzen 5 2500U.
with all the busy background tasks, etc.
