Micro Stuttering
This depends. If you are very sensitive to framerates then it's probably noticeable even with a regular gap of 25ms (40 fps average). If you are not sensitive to framerates then it's not noticeable.
The key is, can SLI or CrossfireX maintain the equivalent framerates (which is lower than the measured framerates) above your sensitivity threshold?
I've never noticed it, even in graphically intensive games like BF3.
But, I don't really try and look for it. If you know what I mean, just play and if it seems smooth enough I'm happy.
