Micro system spec, help
8 Apr 2004
Romsey/Hampshire
*OVERCLOCKED* Intel Core i3 530 Clarkdale 2.93GHz @ 4.00GHz / Gigabyte GA-H55M-UD2H Intel H55 Motherboard / Corsair 4GB DDR3 PC3-12800C9 1600MHz DDR3 Bundle £319.99
(£272.33) £319.99
(£272.33)
Options applied to the above product:
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) £18.99
(£16.16) £18.99
(£16.16)
Microsoft Windows 7 Professional 64-Bit - OEM (FQC-00765) £110.99
(£94.46) £110.99
(£94.46)
Silverstone Sugo SG01B-F Evolution Aluminium Micro-ATX Case - Black £84.99
(£72.33) £84.99
(£72.33)
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply £72.99
(£62.12) £72.99
(£62.12)
Western Digital Caviar Black 640GB SATA-II 32MB Cache - OEM (WD6401AALS) £50.98
(£43.39) £101.96
(£86.78)
Arctic Silver 5 Thermal Compound (3.5g)
Will this work and fit??
An what about optical drives
(£272.33) £319.99
(£272.33)
(£16.16) £18.99
(£16.16)
(£94.46) £110.99
(£94.46)
(£72.33) £84.99
(£72.33)
(£62.12) £72.99
(£62.12)
(£43.39) £101.96
(£86.78)
No.
You need to have a low profile heatsink for the Sugo SG01 and it cannot exceed 78MM in height.
The standard cooler for the Core i3 530 is quite short so it may fit.
I would also get the components separately too instead of the bundle!
You could get the following bits for the same price as the bundle:
Gigabyte GA-H55M-UD2H ~ £85
http://www.overclockers.co.uk/showproduct.php?prodid=MB-233-GI
4GB 1600MHZ DDR3 ~ £77
http://www.overclockers.co.uk/showproduct.php?prodid=MY-041-GS&groupid=701&catid=8&subcat=1517
Core i5-661 ~ £151
http://www.overclockers.co.uk/showproduct.php?prodid=CP-313-IN&groupid=701&catid=6&subcat=1672
A quad core Core i5 750 is the same price though!!
I assume you are going for the Core i3 dual cores due to the integrated graphics.
You could save yourself £53 and overclock a Core i3 530 yourself.
OK thanks, ..
i'll have a closer look, but good advice on the H/S, does intel i3 and i5 still come with a cooler these days?
