** MicroLab Speakers coming to OcUK!! ** - ORDER NOW!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
OcUK have brought on a brand new speaker range from MicroLab offering a selection of 2.0 and 2.1 speakers to suit all needs.
Ranging from the £30 budget up to the higher £80+ theres something suited for everyone!
Watch out for some mini reviews as these speakers are very suprising in both build quality and performance with the SOLO6C offering a quality hi-fi experience for the PC.
MicroLab M700 40W 2.1 Speaker System - Gloss Black Finish @ £29.99 inc VAT
2.1 speaker system with subwoofer for quality sound production. Clear sound and Hi-Fi 2.1 subwoofer system designed for multimedia and computer applications. Bass reflex tunnel for depth and deeper bass effect. Tower satellites with minimum distortion and clearer sound. Comes with front master volume knob for easy adjustment.
- Output power: 40 Watt RMS
- Power distribution: 12 Watt x 2 + 16 Watt
- Harmonic distortion: < 0.3% 1 W 1 kHz
- Frequency response: 35 Hz - 20 kHz
- Signal/Noise ratio: > 75 dB
- Separation: > 45 dB
- Input sensitivity: Satellites - 500 mV, Subwoofer - 130 mV
- Tweeter driver type: 2.5" x 2
- Tweeter rated power: 15 Watt x 2 6 ohm
- Subwoofer driver type: 5"
- Subwoofer rated power: 20 Watt 4 ohm
- Output: RCA
- Input: RCA
Only £29.99 inc VAT.
ORDER NOW
MicroLab FC360 45W 2.1 Speaker System - Silver Finish @ £55.99 inc VAT
Great sounds matters, this system features top quality satellites that perform near perfect linear frequency response curve. Powerful subwoofer with fantastic depth for accurate sound production from all your playback media. Attention to details, this system is truly a must for all who appreciate music and multimedia entertainment. Microlab premier range, the FC series is based on the FINE CONE designed by Acoustic expert, Peter Larsen. This design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Uncolored audio, precise position, and high resolution with Microlab own eAirbass technology
- Powerful 2.1 subwoofer system with full range acoustic production, rich sound and clarity
- X-Bass design, Microlab own proprietory technology - bass with natural depth and range
- 5.25" woofer system for deep vocal and bass effects. All magnetically shielded
- Designed by Denmark acoustic expert, Peter Larsen V12 FineCone technology with perfect linear response
- Standalone amplifier unit for interference free performance and with full front volume controls
- Output power: 45 Watt RMS
- Power distribution: 10 Watt x 2 + 25 watt
- Harmonic distortion: < 0.3% 1W 1kHz
- Frequency response: 35Hz - 20kHz
- Signal/Noise ratio: > 80dB
- Separation: > 50dB
- Input sensitivity: 300mV
- Nominal impedance: 4 ohm
- Tweeter rated power: 10 Watt
- Bass driver type: 5.25" - X-Bass
- Bass rated power: 25 Watt
- Frequency range: 35Hz - 20kHz
- Output: 3RCA sockets
- Input: 3.5mm Stereo, 2RCA
Only £55.99 inc VAT.
ORDER NOW
MicroLab FC330 56W 2.1 Speaker System - Dark Wood Finish @ £44.99 inc VAT
Beautiful wooden cabinet for perfect sound performance, the FC330 is a powerful 2.1 subwoofer speaker system. This system spots deeper bass and high fidelity speaker drivers for excellent performances. High quality tweeters and powerful woofer for your perfect music entertainment and enjoyment. Comes with front volume control and bass control for your preferred sound effects. Microlab premier range, the FC series is based on the FINE CONE designed by Acoustic expert, Peter Larsen. This design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Uncolored audio, precise position, and high resolution with Microlab own eAirbass technology
- Beautiful and powerful 2.1 subwoofer system with full range acoustic production
- X-Bass design, Microlab own proprietory technology - Bass with natural depth and range
- 5.25" Subwoofer system for deep vocal and bass effects and all natural wooden finish
- Front master volume and rear Bass volume controls
- Output power: 56 Watt RMS
- Power distribution: 16 Watt x 2 + 24 Watt
- Signal/Noise ratio: > 80 dB
- Separation: > 52 dB
- Input sensitivity: 360 mV
- Tweeter driver type: 3" x 2
- Tweeter rated power: 16 Watt
- Subwoofer driver type: 5.25" - X-Bass
- Subwoofer rated power: 24 Watt
- Frequency: 35 Hz - 20 kHz
- Output: 2RCA
- Input: 2RCA
Only £44.99 inc VAT.
ORDER NOW
MicroLab X16 68W 2.1 Speaker System - Gloss/Matt Black @ £79.99 inc VAT
Designed for small home system series, the X series consist of a powerful subwoofer and small satellites. This 2.1 subwoofer system is ideal for home movies and music entertainment. Rich sound and powerful bass makes it the ideal choice and excellent all range performer. Built with several proven technologies such as FineCone, Fine Moto, Fine Box, and eAirbass for perfect sound production. Perfect for Home theater layout and watching movies, or enjoying your favourite music, with full cinema acoustics
- Powerful 2.1 subwoofer speaker system for surround effects and acoustics
- Satellites can be on the desk, or wall mounted
- Full range clear acoustic with deep powerful bass
- Designed using many proven technologies such as Finecone V12, FINE BOX, FINE CONE, and FINE MOTO
- Comes with wireless infrared remote control
- Output power: 68 Watt RMS
- Power distribution: 14 Watt x 2 + 40 Watt
- Frequency response: 30 Hz - 20 kHz
- Separation: > 48 dB
- Input sensitivity: 310 mV
- Bass driver type: 6.5" - eAirbass
- Bass rated power: 60 Watt
- Output: RCA
- Input: 3.5 mm stereo, 2RCA
Only £79.99 inc VAT.
ORDER NOW
MicroLab SOLO1C 60W Bookshelf Stereo Speakers - Dark Wood Finish @ £67.99 inc VAT
High fidelity and definition bookshelf stereo speakers with beautiful wood finish. Designed with Microlab special care and audio expertise, this series is ideal for most living room setup. Listen to crystal clear and dynamic music with this stereo pair and witness the quality in its audio drivers.
High resolution and near perfect performances, simply stunning audio production quality.
Great sound and full range audio production. Comes with infrared remote control capability for wireless control. Special heritage range for Microlab's 2.0 system that employs high quality design techniques and speaker technology - perfect sound quality and near linear response. Incorporates IGBT OCL circuit for pure tones and dynamic acoustic production. Wireless remote control for attenuation. High quality sound and full range spectrum, ideal for all music lovers and audiophiles.
- Beautiful wooden cabinets with excellence sound quality, powerful 2-way speaker system
- Crystal clear dynamic highs, balanced mid range and deep bass
- Reference monitor quality, driven by high quality drivers
- Each cabinet with 1" tweeter for high notes and woofer for mid to low depths and bass. Includes wireless remote control.
- Ideal for high fidelity music, movies and digital media playbacks
- Output power: 60 Watt RMS
- Power distribution: 30 Watt x 2
- Frequency response: 64 Hz - 20 kHz
- Separation: > 50 dB
- Input sensitivity: 400 mV
- Tweeter driver type: 1"
- Tweeter rated power: 20 Watt 6 ohm
- Bass driver type: 5"
- Bass rated power: 30 Watt 4 ohm
- Frequency range: 64 Hz - 20 kHz
- Output: DIN jack
- Input: 2RCA jack
- AUX input: 2RCA jack
Only £67.99 inc VAT.
ORDER NOW
MicroLab SOLO6C 100W Bookshelf Stereo Speakers - Dark Wood Finish. @ £83.99 inc VAT
High fidelity bookshelf stereo speakers with beautiful wood finish. Designed with Microlab special care and audio expertise, this series is ideal for most living room setup. Listen to crystal clear and dynamic music with this stereo pair and witness the quality in its audio drivers. High resolution and near perfect performances, simply stunning audio production quality. Powerful sharp cone dispersion design on woofer for perfect audio experience. Comes with infrared remote control capability for wireless remote control. Special heritage range for Microlab's 2.0 system that employs high quality design techniques and speaker technology - perfect sound quality and near linear response Incorporates IGBT OCL circuit for pure tones and dynamic acoustic production. Wireless remote control for attenuation.
- Amplifier: Output power: 100 Watt RMS
- Power distribution: 50 Watt x 2
- Frequency response: 55Hz - 20kHz
- Signal/Noise ratio: > 85dB
- Separation: > 55dB
- Input sensitivity: 440mV
- Speakers: Tweeter driver type: 1"
- Tweeter rated power: 10 Watt 6 ohm
- Frequency range: 55Hz - 20kHz
- Output: Terminals
- Input: 2RCA
- Aux input: 2RCA
- Power: Power supply: AC 220 - 240V, 50Hz
- Package Contents: SOLO6C speakers x 2
- Interconnect cable
- 2RCA - 3.5mm stereo 1.8m cable
- Full function remote control
Only £83.99 inc VAT.
ORDER NOW
The dark wood (84 quid) ones get a decent review. Apparently one of the design consultants who worked for JBL and some other firms helped to design the drivers.
With them being 6.5" you get a decent amount of bass too.
Just been having a play with the SOLO6C and they are excellent! Like a bigger, louder, bassier (If thats even a word) of the Edifier R1600T. I think they're brilliant for the additional cost!
Watch this space as I'll be throwing a review together in the coming days from my time with them this weekend :)
So will I.
What I will recommend is a decent dedicated sound card though as they need to juice to get the best out of them.
Had these plugged into an old laptop with realtek onboard sound and they sounded incredibly amazing!, and that was without messing with the settings in media player etc.
Hopefully today will have the new PC up and running with Xonar D2 :D. (waiting paitently for the last 2 components as i write this, and even though i love games and cant wait to see what the graphics will be like the first thing i wanna do is hear these speakers again, they are show stealers!!:p
How about the SOLO1C vs the Edifiers?
Wow I have the solo6c and my god these things are ridiculously nice.
They go stupidly loud, can handle bass brilliantly if you're a bass head and sound great.
My first proper set of speakers and I have to say they have heightened my music enjoyment.
Fantastic.
