- 1 Aug 2023
- Scotland
Hi Guys, I'd appreciate some advice around my new build which is giving me issues with microphone distortion.
The distortion only occurs when I'm gaming, which I'm presuming is due to the load on the GPU creating coil whine/additional EMI which is causing the issue. The distortion isn't present immediately, the microphone works fine for around 30 mins and then the distortion appears. It doesn't build up over that 30 minutes, it's like someone hits a switch and all of a sudden the distortion appears. If I disconnect the headphones USB connector and then reconnect the distortion disappears but returns 30 minutes later.
I've read previous threads and tried lowering the input and changing the usual suggested settings, but nothing seems to have made any difference.
I'm currently using Hyper X Cloud Revolver 7.1 headphones which connect to the PC via USB. The headphones connect to a control box which lets you adjust volume, mic input etc so not sure if this is essentially doing the job an external sound card would do? I was considering this route but if the control box I currently have is essentially an external sound card it doesn't look like that would help.
Any advice appreciated.
