I'm having some serious issues with my microhpone.
The volume keeps going down towards the bottom.
as you can see here,
(Volym = Volume, Mikrofon = Microphone)
my "rear MIC" is down at the bottom, and if I try to turn it up, it refuses. it just goes down to the same position, and as you also can see, I try turning up the Mic to full but then after 5 seconds it drops to the same position as Rear MIC. so I figured out that if I can turn up Rear MIC, I can keep my Mic at the top, but as I said, it refuses to "be changed", so I was just wondering if there's any way to turn up the Rear MIC ? any help is appreciated.
I tried to raise the volume in MSN, but it refuses to be raised there as well. it just jumps up and down when I try to pull it towards maximum, while holding down the left mouse click. when I release the mouse, It goes back to the bottom again.
I tried disconnecting the microphone, and then raise the volume, but that didn't work either.
It ends up looking like this.
