Microphone problems...K8VSE Asus MB
7 Feb 2004
I thought I had a broken microphone on my headset as it has not been working for a while but I got a new head set and that does not work either.
Does anyone know if there is something on the MB that I need plugging in?
Thanks
Is the correct recording device set?.....
Is the option greyed out, or is it correctly setup and just not working?
You sure its not working, how are you testing?....
You won't here yourself unless you turn microphone playback on.
Control Panel > Sounds and Audio Devices > Advanced
You should then have the playback controls up, if Microphone isnt already listed click Options > Properties and check it.
I assumed this was where you were setting up the mic before. All volumes are for playback, you can set it to recording volumes via the options.
Yeah that section was turned up.
Do you think I might have unplugged the mic on the MB somewhere as I did take it apart to install a new graphics card a few months back?
I was using the back one. I think I may have the problem now.
When I go into voice recording in Sounds and Audio devices the advanced section is faded out.
Which to me would suggest something not plugged in or installed.
Any advice on where a mic connection would be found on my MB? (Asus K8vse)
Thanks
