Well overclockers only sells one desktop microphone. I assume it will be a good one and it says it noise cancelling.
Otherwise you'll need to buy a headset. When i was looking at them this
Sennheiser PC150 Binaural Headset (SP-002-SN)
- Ideal for PCs, laptops, voice recognition & Internet telephony
- Also for CD, MP3, DVD
- Compatible with all major sound cards
- In-line volume control
- Microphone mute
- Noise cancelling microphone
- Super-comfortable, padded headband
- Lightweight design for extended use
- 2 x 3.5 mm jacks for PC sound cards
Full Specification
seemed to be the top one to get in my budget but in the end i never bothered and just type fast instead.
