Hello guys! Im looking for a good microphone that is not too expensive for around 50-100£ that will work with my SoundBlaster x7 so it should be with a jack instead of USB.
If I will buy for example this microphone http://www.akg.com/pro/p/p220
that requirMale/Female and I change it to XLR/Jack will it work with my SoundBlaster x7?
Not quite as simple as that. That microphone needs a phantom power source, which the X7 doesn't provide. You'd need a separate device to connect to the X7, then connect the microphone to that. Behringer PS400 for example.
Why do you need a microphone that works with the X7?
What is the X7 doing that means you don't want a USB one?
Recording speech only or singing/musical instruments? You'll probably have more luck with a decent USB microphone for that budget. X7 isn't really designed as a recording device.
