Microphones/line in
Man of Honour
4 Nov 2002
West Berkshire
I want to connect a handheld microphone to a portable media device, but I have no microphone input sockets, only line in.
I believe I can't just use any old microphone for this, so what do I need?
Thanks.
Either a preamp to boost the mic to line level or a microphone with one built in. No other way around it im afraid!
Getting (or getting someone you know that is handly with a soldering iron to make you) a mic preamp is the easiest way because then you can plug in any mic you like to it rather than hunting one that outputs at line level.
I know mic preamps are pretty easy to build, but I'm not skilled enough, so the 'find one that works' option would be easier. :)
