Microsoft ADS and adsroot.cer
3 Apr 2007
South of the Watford Gap!
Quick question on the above. When I install ADS it installs and creates a certificate file adsroot.cer which I then need to install on a target server if I want to image it. As the file seems to be unique per ADS server install would it be possible to take this file from one ADS server and install it on another. Have sort of tried but when trying to image unless I use the adsroot.cer created on that server it can't connect to the target server.
Reason I'm trying to do this is we have a 'live' ADS server with it's adsroot.cer and I also have a test ADS server in it's own little network and I was hoping to use the same certificate file on both domains/servers, the domain name for both environments is the same by the way if that makes a difference.
