Microsoft edge (please help)
18 Nov 2010
I know there are better browsers to use and I will probably use another one if I can't find a solution to this problem, but anyway, When using microsoft edge when I move my mouse over to the right hand side to use the scroller bar sometimes my mouse can go too far over and won't met me scroll, ie i've got to move it slightly back to the left a bit to use the scroller.
it's just bloody annoying, anything I can do to fix that?
So... how did you sort it? In case anyone else in future pops up with the same issue.
On the Google site itself or Chrome's omnibox (the browser's address box/searchbox)?
google site
It was a seperate question to the above, just wanted to know how to show bookmarks in the tab but its shown easily in settings.
Alright I found the cause with your first problem. The fault is indeed with Edge since it now has a new sidebar. You can hide it but it actually leaves a single pixel wide strip there which is why dragging the scroll bar doesn't work when you move to the far right.
As for the recent searches on Google, you'll have to delete your search history on your Google account. Which is not exactly the best solution if you want to keep it clear all the time.
