After having the same keyboard for 10 years, I thought it's about time to give it a clean out.
As a precuation, I thought i'd check to see if there are any risks or any tips you guys can provide so that I don't end up breaking it.
Is the task a simple case of removing the screws and the keys are attached firmly to the board, so that i can remove the casing, clean it out and simply re-attach the casing again?
Cheers in Advance.
Cheers in Advance.
