- 24 Oct 2005
- Hull
I found this on another forum & just had to share it with you all !
Sorry if its a repost
let microsoft sort this one out
Dear Technical Support,
18 months ago, I upgraded to Girlfriend 1.0 from DrinkingMates 4.2, which I
had used for years without any trouble. However, there are apparently
conflicts between these two products and the only solution was to try and
run Girlfriend 1.0 with the sound turned off.
To make matters worse, Girlfriend 1.0 is incompatible with several other
applications, such as LadsNightOut 3.1, Football 4.5, and Playboy 6.9.
Successive versions of GirlFriend proved no better.
I tried a shareware program, Slapper 2.1, but it had many bugs and left a
virus in my system, forcing me to shut down completely for several weeks.
Eventually, I tried to run GirlFriend 1.2 and Girlfriend 1.0 at the same
time, only to discover that when these two systems detected each other they
caused severe damage to my hardware.
I eventually upgraded to Fiance 1.0, only to discover that this product
soon had to be upgraded further to Wife 1.0. While Wife 1.0 tends to use up
all my available resources, it does come bundled with EmotionalContent v 55
and Cleanhouse2005.
Shortly after this upgrade, however, I found that Wife 1.0 could be very
unstable and costly to run. Any mistakes I made were automatically stored
in Wife 1.0's memory and could not be deleted. They then resurfaced months
later when I had forgotten about them. Wife 1.0 also has an automatic
Diary, Explorer and E-mail filter, and can, without warning, launch
TurboStrop and Multi-Whinge. These latter products have no Help files, and
I have to try to guess what the problem is.
Additional problems are that Wife 1.0 needs updating regularly, requiring
ShoeShop Browser for new attachments and Hairstyle Express which needs to
be reinstalled every other week. Also, when Wife 1.0 attaches itself to my
Volvo C70 Convertible hard drive, it often crashes.
Wife 1.0 also comes with an irritating pop-up called MotherInLaw, which
can't be turned off.
Recently I've been tempted to install Mistress 2005, but there could be
problems. A friend of mine has alerted me to the fact that if Wife 1.0
detects Mistress 2005, it tends to delete all of your Money before
uninstalling itself.
and Cleanhouse2005.
