Microsoft mouse arc scrolling issues in Chrome
Caporegime
7 Apr 2008
Lorville - Hurston
Hi.
i recently purchased the new arc mouse for use with my razer blade stealth laptop and notice that in chrome, when i scroll through any page, it scrolls very very slow making mouse scrolling for chrome useless .
Other programs and browsers scroll perfectly fine.
Any ideas? i triedin incognito and also disabled hardware acceleration and still the mouse scrolls really slow.
I have already installed the drivers and app for the arc mouse too
Hi Jonney,
if you are using windows 10, click the start menu, then the cog icon to bring up the settings menu.
Next click 'devices', and select the 'mouse' tab from the side bar, the third control down should be a slider which controls the amount to scroll for each 'click' of the wheel.
Windows 7 (taken from https://support.microsoft.com/en-gb/help/14206/windows-7-change-mouse-settings) :
- Open Mouse Properties by clicking the Start button The Start button, and then clicking Control Panel. In the search box, type mouse, and then click Mouse.
- Click the Wheel tab, and then do one of the following:
- To set the number of lines the screen will scroll for each notch of mouse wheel movement, under Vertical Scrolling, select The following number of lines at a time, and then enter the number of lines you want to scroll in the box.
- To scroll an entire screen of text for each notch of the mouse wheel, under Vertical Scrolling, select One screen at a time.
- If your mouse has a wheel that supports horizontal scrolling, under Horizontal Scrolling, in the Tilt the wheel to scroll the following number of characters at a time box, enter the number of characters you want to scroll horizontally when you tilt the wheel to the left or right.
Click OK.
hope that helps!
EDIT: sorry just noticed that you said only chrome is affected....there seems to be a plugin to help with that:
https://chrome.google.com/webstore/...th-scr/khpcanbeojalbkpgpmjpdkjnkfcgfkhb?hl=en
Thanks for the post. I tried that scroller extension on chrome and it effects the trackpad as well :(
The trackpad works fine, its just my microsoft arc mouse on chrome :(
