5 Sep 2008 at 22:31 #1 Peve Peve Associate Joined 7 Sep 2003 Posts 1,897 Location Bo'ness Can you get better deals on the Microsoft Points from buying the cards or are you just as well getting them from xbox live? Thanks
5 Sep 2008 at 22:39 #2 Shamikebab Shamikebab Caporegime Joined 9 Mar 2006 Posts 59,272 Location Surrey Yes you can get better deals by buying the cards, depending on the place. I don't really bother though.
5 Sep 2008 at 22:44 #3 JUMPURS JUMPURS Soldato Joined 27 Sep 2004 Posts 11,211 Location The Ledge Beyond The Edge If nothing else, when you buy the cards, depending on the store, they may have some form of reward scheme.
5 Sep 2008 at 22:46 #4 Sinny Sinny Soldato Joined 21 Feb 2007 Posts 9,515 Location Cheshire I bought 2100 MS points for £13.98 delivered offer is still on if you search google.
6 Sep 2008 at 00:45 #5 Red Porsche Red Porsche Associate Joined 5 Jul 2007 Posts 1,293 EVERY LITTLE HELPS.
6 Sep 2008 at 10:26 #7 SiD the Turtle SiD the Turtle Soldato Joined 16 Nov 2003 Posts 9,682 Location On the pale blue dot I try to get them from online shops that are both cheap and use Quidco, so I can get some referral money.
