Microsoft Project 2002 SP1 - real long shot
27 Feb 2004
Kent
I have just had to reinstall this but have just realised that Microsoft no longer supply service packs for out of date software.
Don't suppose anybody has a download of MS Project 2002 (XP) SP1 - I know it's unlikely but not impossible!
Mel
If it's of any help the file you're looking for is called Project2002-KB830241-FullFile-ENU.exe
I have it on an old CDR but sadly it's too unreadable to copy off :(
Thanks but all. searches seem to lead back to MS site and no file is available. I have several cd / dvd drives if you were willing to let me have a try at reading your CDR?
Mel
Fantastic leezer3.
On holiday at moment but have downloaded on to laptop - will try next week!
OCUK forum comes up trumps again!
Mel
Thanks - worked OK then downloaded some extra security updates.
Mel
MS says MS Project 2002 not compatible with win 10. It does run and you can save a MS project file (.mpp). Saving file is OK but MS project doesn't seem to shut down properly.
Im searching the same, but for spanish: Project2002-KB830241-FullFile-ESN.EXE
Here is the web, but download not available: https://web.archive.org/web/2015102...osoft.com/es-es/download/details.aspx?id=5075
Thanks.
This is *probably* what you want- It's the SP1 ISO for the full MUI version of Project 2002, which I think will probably apply to the ES version, as this was an option for the MUI install.
If not, a little digging will find you a MUI copy, which you can set to ES on install :)
Sadly not worked.
If I try with the english version installer I get this:
Is that Windows 98??? :D
I've used project management software all my life. MSP 2002 was outdated in 2002. No idea why you would want it in 2026, even the newest version is poor. Powerproject from Elecosoft is the industry leader and doesn't cost very much more.
