MicroStation (CAD) Question.
20 Oct 2004
Nottingham
Do any of you chaps use MicroStation?
I need a favour if possible. I understand that you can create layers from CSV file and then export the drawing out as an Autocad DWG file.
I have a task of setting up several template files based on Uniclass 2015 layering system (for L2BIM compliance) and each class has a great deal of layers and I wondered if someone would be so kind as to create me the DWG files quickly? Autodesk in their ultimate wisdom decided that create layer from CSV file wasnt something that would be needed. You can do it via LISP I believe but I'm using LT.
