microstutter in Fifa13 with latest catalyst
I got stutters pre 13.2 beta in Fifa13, the DX9 fix from 13.2 beta 3 onwards is working wonders for me.
May be an idea to do a clean sweep then install 13.2 beta5.
Edit: If you are on dual cards, create a catalyst profile, overwrite the current fifa13 profile and leave everything on default apart from crossfire, set that to disable and save. For what ever reason it tries to share load between two cards otherwise when its not required.
What I do for fifa13 is:
Fullscreen / 4x AA / no limit on FPS / VSYNC OFF (gives horrible input lag in this game)
and use MSI or whatever you use to cap the fps at 200 otherwise it goes berserk on menus and crashes.
I dont change things in CCC or readeonpro because for some reason FIFA 13 doesnt like things like this changed (GFX glitches etc)
I use RadeonPro works fine here I use dynamic vsync and locked at 60hz. then on the game everything max but leave no fps limit and let radeonpro do the sync.
Before using the 13.1 or 13.2 i had the 12.10 and never any similar problem. Yesterday i reverted to 12.11 beta 11 just to see them too as well. I should also note that the problem doesn't appear from the 1st minute, but after 3-5 minutes...
I thought the latest 13.2 Beta were really good, until I noticed that it was good with about three games.. Crysis 3 beta, far cry 3 and Skyrim, everything else i started to notice several issues, and open gl was a complete mess for me.
Rage was a total mess, Shift 2 texture flickers, fifa like you stuttering mess, all in all its good to see AMD make a continuation of a mess of their drivers, TBH the 13.1 suite is working very well for me, its 12.11 beta 11 but windows certified so i'm happy with these for now.
Well they are called beta and they also for Crysis 3 you will see that in release notes :p
Stick with 13.1 WHQL
There's no need to turn off MSAA or anything else in Fifa, especially with a 7970.
game was stuttering for me, turned it off and it went away. FPS was solid as it doesnt even touch a 7970 performance wise but like i said it was stuttering for me until i turned it off.
