Microwaving ice cream...
17 Jul 2005
Just had someone go off on one because I microwaved some ice cream to soften it up a bit (microwaved the whole tub)..... before serving it, was way to frozen to get any out.
I understand the dangers of thawing something, and reheating... salmonella and the like - but is ice cream that much of a problem? :s... I've done it for ages, always warmed the tub of ice cream up (only 20 secs to allow me to get it out!)... and never had any probs :s thought it was only really meat and stuff.
Punch them in the ovaries
Then nuke the ice-cream from orbit.
Hehe j/k, should be fine, the problem is when you cook food, let it cool, microwave it, then let it cool, then eat it.
Plus I'd be pretty damn peed off if I caught salmonella from ice-cream, regardless of how many times I reheated it!
Either you dont eat ice cream often and its been in the freezer for ages, or your freezer is turned up way too high :).
You dont want to cook the cream really but.. shouldnt be too much harm..
Id rather run a hot tap as Raymond says even if not only on the scoop but on the packaging as well if its a cart'dor type device...
Seriously, this ice cream is proper freaky. even if you put it in a fridge it stays frozen solid. it just tastes nice, so i keep getting it. other stuff doesn't freeze too much.
OK - serious post here. Let's at least try to be helpful please.
Thawing and re-freezing food encourages bacteria to grow while it's thawed. Bad idea.
Use a hot knife/scoop instead.
Also, I've never heard of ice cream being solid when only chilled, so either it's not meant to be frozen anyway, or you have your fridge/freezer set way too cold.
i dont do it personally, but i know a lot of people who do heat i in the microwave and they have never had problems afaik. I'm certain there's a difference between heating it for a few seconds to make it soft and thawing it out completely though:)
It's a terribly bad idea.
If you look at ice cream counters near the seaside, there have to be a number of tubs to clean the scoop in. It is because of salmonella. I'm not sure what the tubs have to have in them, but I think it's just plain water.
The problem was the salmonella germinated in the water in the single tub/on the scoop then would spread to the ice cream = food poisoning (hence now the requirement for multiple tubs)! I remember watching a program on the tv about this a while back. A guy died from salmonella that he caught from ice cream that was improperly served.
So I think it goes without saying that even melting the edges of ice cream when microwaving it to soften the bulk of it is a bad thing to do.
/I don't get out enough :(
danza said:
I
Yeah you do :p It's just pretty much common sense and if people don't know the dangers of salmonella and how to stop it from getting into your food, they need to go back to school.
Heating ice cream is silly, just leave it out for a bit, about 30 minutes max before you eat it.
