evening folks,ok just put in corsair hx 1000w now the eps12v/atx12v hardwired cable that splits into 2 4 pins cant quite make it to cpu power there is a little extension that came with case, and in case manual it says cpu power extension but has written on it P4 !!!!! is it ok to use this little extension?
mobo is the gigabyte x58 ud3r
cheers!
cheers!
switched it off!!
