Hello all,
I’m a designer but also gamer who is looking to build a completely new set-up within the next month or so. Although I’ve done a lot of reading about searching, I’m not so sure about what components are best for my needs so I’m asking for help selecting.
I do digital painting everyday and in between that use programs like 3DSMax and ZBrush to do 3D work. With this new system I’ll be playing a bunch of games in my free time, mainly the huge steam backlog of games I bought in the sales in anticipation of this build
!! Watching movies, listening to music and internet browsing will also be common practice. I’m wanting this system to last around 4 years.
I’m happy to do things like searching for the best price for the components once I know what specification I’ll be needing.
Approximate Purchase Date:
As soon as I have decided on all the parts and can get the best offer for my timescale (needs to be up and running by at least mid March at the latest). Will be building it within 24 hours of the parts being delivered.
Budget Range: £1000-£1200 including shipping
System Usage from Most to Least Important:
(I’ve linked the system requirements for some of the software)
Digital Painting using Corel Painter, Photoshop CS3 (might upgrade to CS6 after build)
3D modelling using 3DSMax, Maya, Mudbox and ZBrush
Regular Gaming: games such as Sleeping Dogs, Dead Island
Are you buying a monitor: Yes 1920x1080 resolution
I will be using a dual monitor set-up. Planning to buy either Dell UltraSharp U2312HM 23 inch or Dell Ultrasharp U2212HM 22 inch
Parts to Upgrade: All parts since it is a completely new build.
Do you need to buy OS: Yes, Windows 7 Home Premium
Parts Preferences: No preference as such, just wanting to get the best longevity for the price range. I’d rather pay a bit more for quality rather than skimp and have to re-buy sooner.
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Will be using a dual monitor set-up. Planning to buy either Dell UltraSharp U2312HM 23 inch or Dell Ultrasharp U2212HM 22 inch
Additional Comments:
Will definitely be purchasing 16GB RAM, in the 2x8GB format. I also would like a Blu-Ray drive, in terms of what I might do in the future, I thinking RW is best.
I’m aiming for at least 2TB of HDD and a 128GB SSD. Not sure whether to purchase two 1TB HDD and use for work and one for gaming, or just stick to buying a single 2TB HDD.
I’m going to need to buy either a USB wireless adapter or a PCI wireless card. From initial research it seems like the PCI card comes up trumps however any extra advice would be helpful.
I’ve got a mouse already that I can use for now, I just need a wireless keyboard. This was the one I was thinking of buying this one or this one.
After doing some initial research, I've compiled the following parts:
CPU: Intel Core i5 3570K
Motherboard: Gigabyte GA-Z77X-UD3H, Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, D-Sub/ DisplayPort/ DVI/ HDMI, ATX
Or
Asus P8Z77-V, Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0 (x16), DisplayPort/ DVI-D/ HDMI, ATX
Or
Asus P8Z77-V PRO, Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, D-Sub (VGA)/ DisplayPort/ DVI-I/ HDMI, ATX
Thats where i'm up to at the moment. Any help would be greatly appreciated.
!! Watching movies, listening to music and internet browsing will also be common practice. I’m wanting this system to last around 4 years.I’m happy to do things like searching for the best price for the components once I know what specification I’ll be needing.
Overclocking: Maybe
Or
Or
