Looking to hear from anyone who has come up with innovative ideas for installing an EV charger in cases where it's not logistically easy.
We live in a mid-terraced house, the garage and parking space are part of a shared block that is not immediately adjacent to our property, it's about 20-30 yards away. When we bought it in 2008 'nobody' had an EV so running power to the garage wasn't a priority. I can't see a way to do it that doesn't involve us either passing through/on the neighbour's property (and garage) or having to somehow be run along a passageway from our back gate and across a courtyard.
The front 'garden' if you can call it that is too small to replace with a driveway. The shortest distance from our house to the car would be if we parked out the front and then ran a loose cable to it, but that would literally be going across the pavement which I assume isn't allowed / trip hazard / would get run over by pushchairs etc. We could maybe get away with occasionally running a cable out the back to our parking space but that would literally be running diagonally across a courtyard with cars driving over it etc. Slightly left-field option might be if we agreed to swap garages with a neighbour a couple of doors down, our garage is closer to their property (it's actually a coachhouse on top of our garage) and their garage is closer to ours (could run a cable along the back passage without needing to cross the courtyard), but probably be a bit of a faff legally, also officially our garage has a private parking space in front of it but their doesn't due to blocking turning circles etc, so we'd be giving up a parking space if we did that.
I'm pretty much resigned to not having an EV unless we move house or range / charging time improves massively (thereby allowing us to 'fill up' using public services) / lamppost charging is rolled out, but thought I'd check in case anyone has faced similar issues and come up with a solution?
