Midi case choice
7 Nov 2005
Widnes
If only I could add a poll... looking for a midi case. Will be air cooling rather than water. Won't be overclocking. One HDD (optional), one SSD, one graphics card (2700 Super) so pretty basic.
Options I'm stuck between:
  • Fractual MESHIFY C (£90)
  • NZXT H510 (£75)
  • ECLIPSE P400 (£84)
I also looked at the Corsair CARBIDE 275R but reviews are mixed.
Does it really just come down to which I prefer the look of or anything else I should consider?
value wise phanteks P400 Air would be my choice as it come with 3 RGB fans, that might cost you another £30-50 if you get the meshify which just comes with exhaust. had no experience of NZXT but both Fractal and Phanteks are good choices.
The P300A air might be worth a look to. depending on how long you want to wait P500A might be coming march https://www.eteknix.com/stunning-new-products-showcased-by-phanteks-ces-2020/
