Im looking for case ideas.. Ive been looking at the Fractal Design Define C Midi case to replace my Phanteks Enthoo Pro M.
now my problem is.. the define c has 168mm of CPU clearance.. my CPU cooler is 160mm without fans but 171mm with fans.. so I reckon I might be able to adjust the fans and get away with it..
but is there anything else out there that I might be overlooking?
budget is around £100 but could possibly stretch a bit if its worth it.. I cant go any higher than the 480mm height as it wont fit into where it needs to go.
the main reason I was looking at the define c is it has a better front dust filter as even though I like my current case the front dust filter is poor in my eyes.
current case..
current case..
