MIDI tower with decent airflow and 340mm GPU length
1 Nov 2002
Sussex
Any recommendations? Meshify 2 compact would be the one but it’s listed as 340mm, but that could be damn tight!
Have this Phantek P500A and it has what you need.
ALL THE SPACE YOU NEED FOR YOUR COMPONENTS
The Phanteks Eclipse P500A's dimensions of 240 x 510 x 505mm provides users with enough room to install up to ten 3.5″ HDD drives (alternatively 2.5″ SSD drives can be fitted in these bays) and a further three 2.5″ SSD drives can be fitted
There is also clearance for GPUs up to 435mm long as well as a CPU Cooler of up to 190mm and the i/o panel features two USB 3.0 Gen 2 parts, microphone / headphone jack, reset and power buttons.
https://www.overclockers.co.uk/phan...ase-tempered-glass-satin-black-ca-0ac-pt.html
