- 3 Feb 2014
I have a Miele W304 washing machine, and the drain pump is now only pushing out a small amount of water. Apart from that, the machine works perfectly, but of course, the pump isn't draining enough water out, so it times out.
ALL the drains and hoses, inside the machine and external, are completely clear. So are the pump housing chambers and filter. The impeller is undamaged, and the pump spins under power when it should, so obviously there's nothing wrong... Except that it's only passing a little water.
I can't think of anything other than that the pump is partially seized and not running at the correct speed; does anybody have any other ideas?
