- 8 Feb 2004
hi. can someone recommend me a good (stereo?) cable to connect my iPod (from its headphone port) to my amplifier please? thank you
Clarkey said:you want to avoid doing that tbh.
kidloco said:because by using the headphone out you arnt getting the proper line out level, depending how you set the volume will effect the sound coming through your hi-fi, to loud and it will distort etc.
by using a dock and a cable you are transfering the music via line out, the same as say a cd seperate would use to an amp
