Got a bit of a problem. Have been experimenting with server 2012 R2 for work (been using it at home for a while now). Was told that datacentre licences would be fine, but now it's been decided that standard licences will be sufficient.
What I've found from googling is that you can upgrade in place standard to datacentre but not the other way round. As I've got the server set up pretty much as they need to be in production, I'd rather keep the full config as is on the eval version but downgrade to standard on 2 VMs.
Is there a way I can migrate the settings across to a fresh install?
What needs to move is:
DC, DNS DHCP etc. on one and RDP server for the other (the rest I was going to start again on anyway).
Not sure how to go about this if it's possible?
thanks
thanks
