I'm thinking of moving to a watercooled setup on my main rig (Intel DX38BT, Q6600, 2x Radeon HD5770, 1x Geforce 9800GT), but am unsure of my options regarding the motherboard (as far as I can tell there are no compatible kits for the Intel board), and am also unsure of the setup I should be looking at (multiple loops, single loop, multiple rads, what pump(s) etc).
I'm not a total novice to watercooling, I used to use a Swiftech H20-120, but the pump failed and I switched back to air (Tuniq Tower 120), but this would be my first custom watercooling setup. I'm also not a novice to extreme cooling as I've owned three phase change units over the years, but I'm now in the pursuit of silence whilst maintaining the performance of my setup.
So, with the above in mind (specifically the quietness), what kind of kit should I be looking for (don't limit yourselves to what OcUK has in their product lineup, but I will be ordering from OcUK if they do have compatible and worthwhile products). The bit that really confuses me is the intricacies, connectors, barbs, what tubing size, etc etc. Pretty sure I want EK blocks, but again this is only going off a slight bit of reading, and aesthetics (I want to stick to a black/silver theme for the blocks if possible).
I shouldn't have a problem with space in my case, but I do want to keep the minimalistic look currently going on, so the ability to hide the res, pump and rad is a priority, I only really want the tubing to be visible, nothing else. This is how my machine looks at present:
Cheers in advance for the help guys.
