- 2 Dec 2006
Mic wont work?
hey been trying to work out why my mic doesn't work. Its just one of many problems however but that will be a new topic when i am able to rma some parts back as currently need my pc.
Anyway, my mic is "currently unavalible" it didn't work with onboard sound either or with my xfi fatality so whats going on? my friend has the same problem and he has same mobo and same sound card and unlike me his pc is totaly fine. (Which really annoys me because my stuff was ment to be delivered before his so i would have got his working parts but i got screwed over as usual).
Anyway, im presuming this is something to do with vista (64bit if it makes a difference), perhaps an option i am missing? And yes the mike is pluged into the right socket on both of ours and we cant get them to work.
Thanks .
:EDIT:
Intresting it now says its working but still when i try configure it it doesn't pick up any sound. Im not sure what i did to change it to working however.
:EDIT:
Its because i changed it to default.. However that turns everything else to not working so i gues i cant have it as default... what ever that means.
Thanks .
:EDIT:
:EDIT:
