Having read lots of good things about Mikrotik and wanting to upgrade my network to better separate out main network/kids/guests/IoT etc, I thought I'd start with stage 1:
- put my Asus router into AP only mode and replace the router section with a Hex S.
I was aware of what I was getting into before I started. As has been said before, the learning curve is near vertical.
I've e also taken this route because I have more than a passing interest in networking at work (this isn't my main field of work but I've picked up overall ownership for managing our network support team) so I thought it would be a good opportunity to learn more.
The Hex S is a very powerful piece of kit with enterprise levels of config for not a lot of money. Once you get your head around it, RouterOS is brilliant and Winbox, the tool for managing it, is fantastic.
Basic config is easy but I have discovered more than once that it's easy to break things.
My biggest issue so far.....
I'm struggling with routing DNS queries through my PiHole though which is on a static IP of 192.168.1.2 (I use 192.168.1.0/24 for my network). I put the PiHole IP into the DNS section under the DHCP server and untick "use peer DNS" on the interface. At this point, the connection falls over with a constant repeat of connecting....terminating - unable to obtain IP address....etc
The router gets stuck in this loop and will not recover from it. The only way I have found is to 'reset configuration' and start all over again. If I reset then restore a known working backup, the connection issue comes back so it will only work again if I manually rebuild the config/rules again. Slightly frustrating!
My guess is that the interface is getting stuck in some sort of unobtainable loop. The PiHole works fine if I manually configure the DNS on a device (eg mobile phone)
With this in mind, I think it must be a firewall config issue. I've followed the Mikrotik guidance to pretty well lock down my firewall so I'm guessing I might need to either pass through port 53 or add the PiHole IP to one of my firewall rules.
I've found various online guides which suggest this might be the case but I don't want to risk breaking it all again. This YouTube video also suggests I need to do some firewall config:
Any Mikrotik experts here that have managed to implement something similar?
