Hi,
I am coming here in hopes that someone can help me, the minecraft forums is a cesspit, with the odd genius out of the 1000's on it.
I have this constant crash while playing minecraft, this is with vanilla or modpacks such as FTB and Technic.
Can anyone pinpoint the problem, I know for a fact it's this computer since it works fine on any other machine, including the ones in college that have strict writing permissions lol.
It seems the exact same crash as this "EXCEPTION_ACCESS_VIOLATION (0xc0000005)", with plenty of googling all the suggestions fail.
Here is the crash report :-
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00000000003f0036, pid=3144, tid=112
# JRE version: 7.0_13-b20
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.7-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C 0x00000000003f0036
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x00000000020c9000): GCTaskThread [stack: 0x0000000000000000,0x0000000000000000] [id=112]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x0000000000000008 0x00000000003f0036
Registers:
RAX=0x00000000fc2bcaf0, RBX=0x00000000e4695de0, RCX=0x00000000fc2bd380, RDX=0x00000000e4695de0
RSP=0x000000000567f5c8, RBP=0x00000000020c20b0, RSI=0x000000000567f760, RDI=0x00000000e473b630
R8 =0x000000000567f760, R9 =0x00000000021261b0, R10=0x0000000000000001, R11=0x000000000000000c
R12=0x00000000020c9390, R13=0x00000000020c20b0, R14=0x000000000567f760, R15=0x00000000020c93a0
RIP=0x00000000003f0036, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x000000000567f5c8)
0x000000000567f5c8: 00000000689b5d17 00000000e4695dc0
0x000000000567f5d8: 000000000567f760 00000000020c20b0
0x000000000567f5e8: 00000000e473b630 000000000213f720
0x000000000567f5f8: 0000000068c28312 00000000021bc030
0x000000000567f608: 0000000000000003 000000000007a8c0
0x000000000567f618: 0000000015714ea0 00000000020c9778
0x000000000567f628: 00000000e46117c0 00000000000253ce
0x000000000567f638: 00000000020c9000 00000000020c20e0
0x000000000567f648: 00000000020c9780 00000000020c9790
0x000000000567f658: 00000000020c9b68 000000000567f810
0x000000000567f668: 0000000068b13dd4 00000000020c9390
0x000000000567f678: 00000000020c9390 00000000020c9000
0x000000000567f688: 00000000021bbfb0 000000000567f7a0
0x000000000567f698: 0000000068c301e3 0000000000000000
0x000000000567f6a8: 000000000906f370 00000000020c20b0
0x000000000567f6b8: 0000000000000003 000000000213f720
Instructions: (pc=0x00000000003f0036)
0x00000000003f0016: 00 00 0c 00 00 00 02 00 00 00 01 01 00 00 00 00
0x00000000003f0026: 00 00 40 9f 3b 00 00 00 00 00 42 00 00 00 00 00
0x00000000003f0036: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x00000000003f0046: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Register to memory mapping:
RAX=0x00000000fc2bcaf0 is an oop
{constant pool}
- klass: {other class}
- holder: 0x00000000fc2bd3f0
- cache: 0x00000000fc2be4e0
- 1 : : 'ka'
- 2 : : 'ka' {0xfc2bd3f0}
- 3 : : 'java/lang/Object'
- 4 : : 'java/lang/Object' {0xfae02de0}
- 5 : : 'SourceFile'
- 6 : : 'a'
- 7 : : 'I'
- 8 : : 'b'
- 9 : : 'Ljava/lang/Object;'
- 10 : : 'c'
- 11 : : 'Lka;'
- 12 : : 'd'
- 13 : : '<init>'
- 14 : : '(IILjava/lang/Object;Lka
V'
- 15 : : '()V'
- 16 : : name_index=13 signature_index=15
- 17 : : klass_index=4 name_and_type_index=16
- 18 : : name_index=8 signature_index=9
- 19 : : klass_index=2 name_and_type_index=18
- 20 : : name_index=10 signature_index=11
- 21 : : klass_index=2 name_and_type_index=20
- 22 : : name_index=6 signature_index=7
- 23 : : klass_index=2 name_and_type_index=22
- 24 : : name_index=12 signature_index=7
- 25 : : klass_index=2 name_and_type_index=24
- 26 : : '()I'
- 27 : : '()Ljava/lang/Object;'
- 28 : : 'equals'
- 29 : : '(Ljava/lang/Object
Z'
- 30 : : name_index=6 signature_index=26
- 31 : : klass_index=2 name_and_type_index=30
- 32 : : 'java/lang/Integer'
- 33 : : 'java/lang/Integer'
- 34 : : 'valueOf'
- 35 : : '(I)Ljava/lang/Integer;'
- 36 : : name_index=34 signature_index=35
- 37 : : klass_index=33 name_and_type_index=36
- 38 : : name_index=28 signature_index=29
- 39 : : klass_index=4 name_and_type_index=38
- 40 : : name_index=8 signature_index=27
- 41 : : klass_index=2 name_and_type_index=40
- 42 : : 'hashCode'
- 43 : : 'jz'
- 44 : : 'jz'
- 45 : : 'f'
- 46 : : '(I)I'
- 47 : : name_index=45 signature_index=46
- 48 : : klass_index=44 name_and_type_index=47
- 49 : : 'toString'
- 50 : : '()Ljava/lang/String;'
- 51 : : 'java/lang/StringBuilder'
- 52 : : 'java/lang/StringBuilder'
- 53 : : klass_index=52 name_and_type_index=16
- 54 : : 'append'
- 55 : : '(I)Ljava/lang/StringBuilder;'
- 56 : : name_index=54 signature_index=55
- 57 : : klass_index=52 name_and_type_index=56
- 58 : : '='
- 59 : : "=" {0xe64307d0}
- 60 : : '(Ljava/lang/String
- 61 : : name_index=54 signature_index=60
- 62 : : klass_index=52 name_and_type_index=61
- 63 : : '(Ljava/lang/Object
- 64 : : name_index=54 signature_index=63
- 65 : : klass_index=52 name_and_type_index=64
- 66 : : name_index=49 signature_index=50
- 67 : : klass_index=52 name_and_type_index=66
- 68 : : 'Code'
- 69 : : 'LineNumberTable'
RBX=
[error occurred during error reporting (printing register info), id 0xc0000005]
Stack: [0x0000000000000000,0x0000000000000000], sp=0x000000000567f5c8, free space=88573k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x00000000020c9390
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000000001809d000 JavaThread "NEI Item Loading Thread" [_thread_blocked, id=2992, stack(0x0000000016400000,0x0000000016500000)]
0x000000001809c800 JavaThread "File IO Thread" [_thread_blocked, id=4352, stack(0x000000001ec10000,0x000000001ed10000)]
0x0000000010ceb000 JavaThread "Thread-24" [_thread_blocked, id=2652, stack(0x000000001de60000,0x000000001df60000)]
0x0000000010ce9800 JavaThread "Server thread" [_thread_blocked, id=4940, stack(0x000000001e600000,0x000000001e700000)]
0x0000000010ce7800 JavaThread "Snooper Timer" daemon [_thread_blocked, id=1012, stack(0x000000001e500000,0x000000001e600000)]
0x0000000010ce9000 JavaThread "Thread-16" [_thread_blocked, id=1052, stack(0x000000001cc00000,0x000000001cd00000)]
0x0000000010ce8000 JavaThread "Thread-15" [_thread_blocked, id=3744, stack(0x000000001cad0000,0x000000001cbd0000)]
0x0000000010ce6800 JavaThread "TC Aura Update Thread" [_thread_blocked, id=4012, stack(0x000000000f5f0000,0x000000000f6f0000)]
0x0000000010ce6000 JavaThread "TC Aura Deletion Thread" [_thread_blocked, id=3608, stack(0x000000001c920000,0x000000001ca20000)]
0x0000000010ce5000 JavaThread "TC Aura Calculation Thread" [_thread_blocked, id=2776, stack(0x000000001c7d0000,0x000000001c8d0000)]
0x00000000021bc800 JavaThread "DestroyJavaVM" [_thread_blocked, id=4216, stack(0x0000000002470000,0x0000000002570000)]
0x0000000016e08000 JavaThread "Minecraft main thread" [_thread_blocked, id=3312, stack(0x000000000ca00000,0x000000000cb00000)]
0x0000000015a67800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=560, stack(0x000000000c7f0000,0x000000000c8f0000)]
0x000000000a564000 JavaThread "Snooper Timer" daemon [_thread_blocked, id=2724, stack(0x0000000016300000,0x0000000016400000)]
0x000000000a6a7800 JavaThread "Thread-4" [_thread_blocked, id=3248, stack(0x000000000e520000,0x000000000e620000)]
0x000000000a5f3800 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=2800, stack(0x000000000de30000,0x000000000df30000)]
0x000000000a0f5000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=568, stack(0x000000000cfe0000,0x000000000d0e0000)]
0x000000000a445000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3552, stack(0x000000000b080000,0x000000000b180000)]
0x000000000a058000 JavaThread "AWT-Shutdown" [_thread_blocked, id=4568, stack(0x000000000af20000,0x000000000b020000)]
0x000000000a0df000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3680, stack(0x000000000adc0000,0x000000000aec0000)]
0x0000000008ed0000 JavaThread "Service Thread" daemon [_thread_blocked, id=4828, stack(0x00000000092d0000,0x00000000093d0000)]
0x0000000008ebf000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=4636, stack(0x0000000009b00000,0x0000000009c00000)]
0x0000000008ead000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=1692, stack(0x0000000009a00000,0x0000000009b00000)]
0x0000000008eac000 JavaThread "Attach Listener" daemon [_thread_blocked, id=5096, stack(0x0000000009850000,0x0000000009950000)]
0x0000000008ea4800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1940, stack(0x0000000009670000,0x0000000009770000)]
0x0000000008ea3000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=3572, stack(0x00000000093d0000,0x00000000094d0000)]
0x0000000008e1f000 JavaThread "Finalizer" daemon [_thread_blocked, id=3956, stack(0x00000000091a0000,0x00000000092a0000)]
0x0000000008e18800 JavaThread "Reference Handler" daemon [_thread_blocked, id=4200, stack(0x00000000090a0000,0x00000000091a0000)]
Other Threads:
0x0000000008e10000 VMThread [stack: 0x0000000008f70000,0x0000000009070000] [id=3152]
0x0000000008ed3800 WatcherThread [stack: 0x0000000009c10000,0x0000000009d10000] [id=4028]
=>0x00000000020c9000 (exited) GCTaskThread [stack: 0x0000000000000000,0x0000000000000000] [id=112]
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x00000000021bad30] Threads_lock - owner thread: 0x0000000008e10000
[0x00000000021bb2b0] Heap_lock - owner thread: 0x0000000002126800
Heap
par new generation total 153344K, used 55018K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
eden space 136320K, 37% used [0x00000000dae00000, 0x00000000de03f590, 0x00000000e3320000)
from space 17024K, 20% used [0x00000000e43c0000, 0x00000000e473b630, 0x00000000e5460000)
to space 17024K, 0% used [0x00000000e3320000, 0x00000000e3320000, 0x00000000e43c0000)
concurrent mark-sweep generation total 353920K, used 259205K [0x00000000e5460000, 0x00000000fae00000, 0x00000000fae00000)
concurrent-mark-sweep perm gen total 83968K, used 70942K [0x00000000fae00000, 0x0000000100000000, 0x0000000100000000)
Card table byte_map: [0x0000000005790000,0x00000000058c0000] byte_map_base: 0x00000000050b9000
Polling page: 0x0000000000220000
Code Cache [0x0000000002570000, 0x0000000003200000, 0x0000000005570000)
total_blobs=4615 nmethods=3588 adapters=976 free_code_cache=36510Kb largest_free_block=37193152
Compilation events (10 events):
Event: 678.486 Thread 0x0000000008ebf000 3957 codechicken.nei.SaveLoadButton::update (120 bytes)
Event: 678.487 Thread 0x0000000008ebf000 nmethod 3957 0x000000000317b990 code [0x000000000317bac0, 0x000000000317bb38]
Event: 679.892 Thread 0x0000000008ead000 3958 com.xcompwiz.mystcraft.client.gui.GuiWritingDesk::isNotebook (28 bytes)
Event: 679.893 Thread 0x0000000008ead000 nmethod 3958 0x000000000317b6d0 code [0x000000000317b820, 0x000000000317b8d8]
Event: 682.670 Thread 0x0000000008ebf000 3959 aky::i (88 bytes)
Event: 682.680 Thread 0x0000000008ebf000 nmethod 3959 0x00000000031ed9d0 code [0x00000000031edba0, 0x00000000031edfd0]
Event: 684.038 Thread 0x0000000008ead000 3960 com.xcompwiz.mystcraft.entity.EntityLinkbook::getBookHealth (22 bytes)
Event: 684.040 Thread 0x0000000008ead000 nmethod 3960 0x0000000002d50850 code [0x0000000002d509a0, 0x0000000002d50a98]
Event: 684.074 Thread 0x0000000008ebf000 3961 com.xcompwiz.mystcraft.entity.EntityLinkbook::j_ (127 bytes)
Event: 684.088 Thread 0x0000000008ebf000 nmethod 3961 0x0000000002dfb710 code [0x0000000002dfb920, 0x0000000002dfbf70]
GC Heap History (10 events):
Event: 624.921 GC heap before
{Heap before GC invocations=113 (full 86):
par new generation total 153344K, used 140006K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
eden space 136320K, 100% used [0x00000000dae00000, 0x00000000e3320000, 0x00000000e3320000)
from space 17024K, 21% used [0x00000000e3320000, 0x00000000e36b99d8, 0x00000000e43c0000)
to space 17024K, 0% used [0x00000000e43c0000, 0x00000000e43c0000, 0x00000000e5460000)
concurrent mark-sweep generation total 353920K, used 262670K [0x00000000e5460000, 0x00000000fae00000, 0x00000000fae00000)
concurrent-mark-sweep perm gen total 83968K, used 70923K [0x00000000fae00000, 0x0000000100000000, 0x0000000100000000)
Event: 624.942 GC heap after
Heap after GC invocations=114 (full 86):
par new generation total 153344K, used 2384K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
eden space 136320K, 0% used [0x00000000dae00000, 0x00000000dae00000, 0x00000000e3320000)
from space 17024K, 14% used [0x00000000e43c0000, 0x00000000e46141c0, 0x00000000e5460000)
Event: 641.374 GC heap before
{Heap before GC invocations=114 (full 87):
par new generation total 153344K, used 138704K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
concurrent mark-sweep generation total 353920K, used 259442K [0x00000000e5460000, 0x00000000fae00000, 0x00000000fae00000)
concurrent-mark-sweep perm gen total 83968K, used 70925K [0x00000000fae00000, 0x0000000100000000, 0x0000000100000000)
Event: 641.390 GC heap after
Heap after GC invocations=115 (full 87):
par new generation total 153344K, used 2987K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
from space 17024K, 17% used [0x00000000e3320000, 0x00000000e360ace8, 0x00000000e43c0000)
Event: 654.923 GC heap before
{Heap before GC invocations=115 (full 88):
par new generation total 153344K, used 139307K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
concurrent-mark-sweep perm gen total 83968K, used 70932K [0x00000000fae00000, 0x0000000100000000, 0x0000000100000000)
Event: 654.938 GC heap after
Heap after GC invocations=116 (full 88):
par new generation total 153344K, used 3545K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
from space 17024K, 20% used [0x00000000e43c0000, 0x00000000e4736710, 0x00000000e5460000)
Event: 670.222 GC heap before
{Heap before GC invocations=116 (full 88):
par new generation total 153344K, used 139865K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
concurrent mark-sweep generation total 353920K, used 259189K [0x00000000e5460000, 0x00000000fae00000, 0x00000000fae00000)
concurrent-mark-sweep perm gen total 83968K, used 70936K [0x00000000fae00000, 0x0000000100000000, 0x0000000100000000)
Event: 670.237 GC heap after
Heap after GC invocations=117 (full 88):
par new generation total 153344K, used 3564K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
from space 17024K, 20% used [0x00000000e3320000, 0x00000000e369b148, 0x00000000e43c0000)
Event: 680.635 GC heap before
{Heap before GC invocations=117 (full 89):
par new generation total 153344K, used 139884K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
concurrent-mark-sweep perm gen total 83968K, used 70941K [0x00000000fae00000, 0x0000000100000000, 0x0000000100000000)
Event: 680.649 GC heap after
Heap after GC invocations=118 (full 89):
par new generation total 153344K, used 3565K [0x00000000dae00000, 0x00000000e5460000, 0x00000000e5460000)
Deoptimization events (10 events):
Event: 575.785 Thread 0x0000000010ce5000 Uncommon trap -10 fr.pc 0x000000000313aae4
Event: 575.789 Thread 0x0000000010ce5000 Uncommon trap -10 fr.pc 0x0000000002dd5f7c
Event: 575.789 Thread 0x0000000010ce5000 Uncommon trap -10 fr.pc 0x000000000313aae4
Event: 655.096 Thread 0x0000000016e08000 Uncommon trap -12 fr.pc 0x00000000031f3870
Event: 662.032 Thread 0x0000000016e08000 Uncommon trap -34 fr.pc 0x00000000031e7008
Event: 662.046 Thread 0x0000000016e08000 Uncommon trap -34 fr.pc 0x00000000030ed498
Event: 662.047 Thread 0x0000000016e08000 Uncommon trap -34 fr.pc 0x00000000031e7008
Event: 662.063 Thread 0x0000000016e08000 Uncommon trap -34 fr.pc 0x00000000030ed498
Event: 662.063 Thread 0x0000000016e08000 Uncommon trap -34 fr.pc 0x00000000031e7008
Event: 684.197 Thread 0x0000000016e08000 Uncommon trap -12 fr.pc 0x000000000311c948
Internal exceptions (10 events):
Event: 684.234 Thread 0x0000000010ce8000 Threw 0x00000000dd7c1e30 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.261 Thread 0x0000000010ce8000 Threw 0x00000000ddb339d0 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.287 Thread 0x0000000010ce8000 Threw 0x00000000ddb33b90 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.302 Thread 0x0000000010ce8000 Threw 0x00000000ddb33d50 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.318 Thread 0x0000000010ce8000 Threw 0x00000000ddb33f10 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.340 Thread 0x0000000010ce8000 Threw 0x00000000ddb340d0 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.360 Thread 0x0000000010ce8000 Threw 0x00000000ddb34290 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.393 Thread 0x0000000010ce8000 Threw 0x00000000ddb34450 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.423 Thread 0x0000000010ce8000 Threw 0x00000000ddb34610 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 684.449 Thread 0x0000000010ce8000 Threw 0x00000000ddb347d0 at C:\jdk7u2_64p\jdk7u13\hotspot\src\share\vm\prims\jvm.cpp:2888
Events (10 events):
Event: 679.828 Thread 0x000000001809d000 Thread added: 0x000000001809d000
Event: 679.844 Executing VM operation: RevokeBias
Event: 679.844 Executing VM operation: RevokeBias done
Event: 679.844 Thread 0x000000001809d000 Thread exited: 0x000000001809d000
Event: 680.635 Executing VM operation: GenCollectForAllocation
Event: 680.649 Executing VM operation: GenCollectForAllocation done
Event: 684.194 Thread 0x000000001809d000 Thread added: 0x000000001809d000
Event: 684.197 Thread 0x0000000016e08000 DEOPT PACKING pc=0x000000000311c948 sp=0x000000000cafea70
Event: 684.197 Thread 0x0000000016e08000 DEOPT UNPACKING pc=0x00000000025a9164 sp=0x000000000cafea20 mode 2
Event: 684.476 Executing VM operation: CMS_Final_Remark
Dynamic libraries:
0x000000013f1f0000 - 0x000000013f223000 C:\Program Files\Java\jre7\bin\javaw.exe
0x0000000077890000 - 0x0000000077a3c000 C:\Windows\SYSTEM32\ntdll.dll
0x0000000077770000 - 0x000000007788f000 C:\Windows\system32\kernel32.dll
0x000007fefd4a0000 - 0x000007fefd50c000 C:\Windows\system32\KERNELBASE.dll
0x000007fefee00000 - 0x000007fefeedb000 C:\Windows\system32\ADVAPI32.dll
0x000007fefed60000 - 0x000007fefedff000 C:\Windows\system32\msvcrt.dll
0x000007fefeb60000 - 0x000007fefeb7f000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefd530000 - 0x000007fefd65e000 C:\Windows\system32\RPCRT4.dll
0x0000000077300000 - 0x00000000773fa000 C:\Windows\system32\USER32.dll
0x000007fefef70000 - 0x000007fefefd7000 C:\Windows\system32\GDI32.dll
0x000007fefeb00000 - 0x000007fefeb0e000 C:\Windows\system32\LPK.dll
0x000007fefdc20000 - 0x000007fefdcea000 C:\Windows\system32\USP10.dll
0x000007fefcc70000 - 0x000007fefce64000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_fa62ad231704eab7\COMCTL32.dll
0x000007fefeef0000 - 0x000007fefef61000 C:\Windows\system32\SHLWAPI.dll
0x000007fefd9e0000 - 0x000007fefda0e000 C:\Windows\system32\IMM32.DLL
0x000007fefd790000 - 0x000007fefd899000 C:\Windows\system32\MSCTF.dll
0x0000000071690000 - 0x0000000071761000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x0000000068910000 - 0x000000006902f000 C:\Program Files\Java\jre7\bin\server\jvm.dll
0x000007fef3970000 - 0x000007fef3979000 C:\Windows\system32\WSOCK32.dll
0x000007fefd660000 - 0x000007fefd6ad000 C:\Windows\system32\WS2_32.dll
0x000007fefeee0000 - 0x000007fefeee8000 C:\Windows\system32\NSI.dll
0x000007fef9340000 - 0x000007fef937b000 C:\Windows\system32\WINMM.dll
0x0000000077a60000 - 0x0000000077a67000 C:\Windows\system32\PSAPI.DLL
0x0000000074170000 - 0x000000007417f000 C:\Program Files\Java\jre7\bin\verify.dll
0x0000000074140000 - 0x0000000074168000 C:\Program Files\Java\jre7\bin\java.dll
0x0000000073dd0000 - 0x0000000073de5000 C:\Program Files\Java\jre7\bin\zip.dll
0x0000000073db0000 - 0x0000000073dc9000 C:\Program Files\Java\jre7\bin\net.dll
0x000007fefc6d0000 - 0x000007fefc724000 C:\Windows\system32\mswsock.dll
0x000007fefc6c0000 - 0x000007fefc6c7000 C:\Windows\System32\wship6.dll
0x0000000073d90000 - 0x0000000073da1000 C:\Program Files\Java\jre7\bin\nio.dll
0x000000006e3a0000 - 0x000000006e533000 C:\Program Files\Java\jre7\bin\awt.dll
0x000007fefd6b0000 - 0x000007fefd787000 C:\Windows\system32\OLEAUT32.dll
0x000007fefda10000 - 0x000007fefdc12000 C:\Windows\system32\ole32.dll
0x000007fefb1d0000 - 0x000007fefb1e8000 C:\Windows\system32\DWMAPI.DLL
0x000007fefb600000 - 0x000007fefb656000 C:\Windows\system32\uxtheme.dll
0x000007fefd070000 - 0x000007fefd07f000 C:\Windows\system32\CRYPTBASE.dll
0x000007feee070000 - 0x000007feee26f000 C:\Windows\system32\d3d9.dll
0x000007fefbc60000 - 0x000007fefbc6c000 C:\Windows\system32\VERSION.dll
0x000007feff970000 - 0x000007feff977000 C:\Windows\system32\d3d8thk.dll
0x000007feec830000 - 0x000007feed967000 C:\Windows\system32\nvd3dumx.dll
0x000007fefaf10000 - 0x000007fefaf3c000 C:\Windows\system32\powrprof.dll
0x000007fefeb80000 - 0x000007fefed57000 C:\Windows\system32\SETUPAPI.dll
0x000007fefd460000 - 0x000007fefd496000 C:\Windows\system32\CFGMGR32.dll
0x000007fefd360000 - 0x000007fefd37a000 C:\Windows\system32\DEVOBJ.dll
0x000007fefdd70000 - 0x000007fefeaf7000 C:\Windows\system32\SHELL32.dll
0x0000000072960000 - 0x0000000072994000 C:\Program Files\Java\jre7\bin\fontmanager.dll
0x0000000072910000 - 0x0000000072951000 C:\Program Files\Java\jre7\bin\t2k.dll
0x00000000728e0000 - 0x000000007290a000 C:\Program Files\Java\jre7\bin\dcpr.dll
0x0000000180000000 - 0x0000000180048000 C:\Users\Stacey x\Downloads\Direwolf20\minecraft\bin\natives\lwjgl64.dll
0x000007fef5b10000 - 0x000007fef5c2d000 C:\Windows\system32\OPENGL32.dll
0x000007feff6d0000 - 0x000007feff6fd000 C:\Windows\system32\GLU32.dll
0x000007fef4b10000 - 0x000007fef4c01000 C:\Windows\system32\DDRAW.dll
0x000007feffb00000 - 0x000007feffb08000 C:\Windows\system32\DCIMAN32.dll
0x000007fefc730000 - 0x000007fefc747000 C:\Windows\system32\CRYPTSP.dll
0x000007fefc410000 - 0x000007fefc457000 C:\Windows\system32\rsaenh.dll
0x000007fefc180000 - 0x000007fefc19e000 C:\Windows\system32\USERENV.dll
0x000007fefd140000 - 0x000007fefd14f000 C:\Windows\system32\profapi.dll
0x000007fefadc0000 - 0x000007fefadd5000 C:\Windows\system32\NLAapi.dll
0x000007fefc550000 - 0x000007fefc5ab000 C:\Windows\system32\DNSAPI.dll
0x000007fef95b0000 - 0x000007fef95bb000 C:\Windows\System32\winrnr.dll
0x000007fef93d0000 - 0x000007fef93e5000 C:\Windows\system32\napinsp.dll
0x000007fef93b0000 - 0x000007fef93c9000 C:\Windows\system32\pnrpnsp.dll
0x0000000074840000 - 0x0000000074866000 C:\Program Files\Bonjour\mdnsNSP.dll
0x000007fefa830000 - 0x000007fefa857000 C:\Windows\system32\Iphlpapi.DLL
0x000007fefabc0000 - 0x000007fefabcb000 C:\Windows\system32\WINNSI.DLL
0x000007fefbb90000 - 0x000007fefbb97000 C:\Windows\System32\wshtcpip.dll
0x000007fef8ca0000 - 0x000007fef8ca8000 C:\Windows\system32\rasadhlp.dll
0x000007fefcea0000 - 0x000007fefcef3000 C:\Windows\System32\fwpuclnt.dll
0x0000000073d70000 - 0x0000000073d77000 C:\Program Files\Java\jre7\bin\jawt.dll
0x00000000637b0000 - 0x0000000065196000 C:\Windows\system32\nvoglv64.DLL
0x000007fefd380000 - 0x000007fefd3b9000 C:\Windows\system32\WINTRUST.dll
0x000007fefd1f0000 - 0x000007fefd35a000 C:\Windows\system32\CRYPT32.dll
0x000007fefd1e0000 - 0x000007fefd1ef000 C:\Windows\system32\MSASN1.dll
0x000007fefaeb0000 - 0x000007fefaedd000 C:\Windows\system32\ntmarta.dll
0x000007fefeb10000 - 0x000007fefeb60000 C:\Windows\system32\WLDAP32.dll
0x0000000073920000 - 0x0000000073944000 C:\Program Files\Java\jre7\bin\sunec.dll
0x0000000073d80000 - 0x0000000073d8b000 C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x000007fef2220000 - 0x000007fef2342000 C:\Users\Stacey x\Downloads\Direwolf20\minecraft\bin\natives\OpenAL64.dll
0x000007feff000000 - 0x000007feff088000 C:\Windows\system32\dsound.dll
0x000007fefd940000 - 0x000007fefd9d9000 C:\Windows\system32\CLBCatQ.DLL
0x000007fefb1f0000 - 0x000007fefb23b000 C:\Windows\System32\MMDevApi.dll
0x000007fefb660000 - 0x000007fefb78c000 C:\Windows\System32\PROPSYS.dll
0x000007fef9270000 - 0x000007fef92ab000 C:\Windows\system32\wdmaud.drv
0x0000000074ba0000 - 0x0000000074ba6000 C:\Windows\system32\ksuser.dll
0x000007fefaf00000 - 0x000007fefaf09000 C:\Windows\system32\AVRT.dll
0x000007fef92b0000 - 0x000007fef92ff000 C:\Windows\system32\AUDIOSES.DLL
0x000007fef93a0000 - 0x000007fef93aa000 C:\Windows\system32\msacm32.drv
0x000007fef9380000 - 0x000007fef9398000 C:\Windows\system32\MSACM32.dll
0x000007fef9330000 - 0x000007fef9339000 C:\Windows\system32\midimap.dll
0x0000000074020000 - 0x000000007402b000 C:\Program Files\Java\jre7\bin\management.dll
0x000007fefcc40000 - 0x000007fefcc51000 C:\Windows\system32\dhcpcsvc6.DLL
0x000007fefa860000 - 0x000007fefa878000 C:\Windows\system32\dhcpcsvc.DLL
0x000007fef16e0000 - 0x000007fef1805000 C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xms256M -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:+AggressiveOpts
java_command: net.ftb.mclauncher.MinecraftLauncher C:\Users\Stacey x\Downloads/Direwolf20/minecraft C:\Users\Stacey x\AppData\Roaming/ftblauncher/ModPacks\Direwolf20\FTB_temp.gif MinecraftForge.zip Stacey93 7157895822309009781 Direwolf20 Pack v5.1.0 C:\Users\Stacey x\AppData\Roaming/ftblauncher/ModPacks\Direwolf20\logo_ftb.png
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jre7\bin
USERNAME=Stacey x
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 23 Stepping 10, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7600
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, tsc
Memory: 4k page, physical 4193400k(1199952k free), swap 8384892k(4229840k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (23.7-b01) for windows-amd64 JRE (1.7.0_13-b20), built on Jan 30 2013 10:10:00 by "java_re" with unknown MS VC++:1600
time: Tue Feb 19 00:26:27 2013
elapsed time: 684 seconds
Registers:
{constant pool}
- 1 : : 'ka'
- 6 : : 'a'
- 7 : : 'I'
- 8 : : 'b'
- 10 : : 'c'
- 11 : : 'Lka;'
- 12 : : 'd'
- 13 : : '<init>'
- 15 : : '()V'
- 26 : : '()I'
- 28 : : 'equals'
- 34 : : 'valueOf'
- 42 : : 'hashCode'
- 43 : : 'jz'
- 44 : : 'jz'
- 45 : : 'f'
- 46 : : '(I)I'
- 49 : : 'toString'
- 54 : : 'append'
- 58 : : '='
- 68 : : 'Code'
RBX=
Other Threads:
Heap
Events (10 events):
Dynamic libraries:
VM Arguments:
USERNAME=Stacey x
OS=Windows_NT
