Minecraft Crashing, hardware?
5 Sep 2010
Hi,
Recently my minecraft has been crashing every 30 seconds to 20 minutes, at random.
I have posted in the software section but just done a clean install of Windows, it crashes with Vanilla Minecraft, FTB mod pack and Technic mod pack, all giving the same error code.
I am beginning to think its my hardware, is anyone here any good at locating hardware related crashes in java error logs? To help me pin down the problem, this error code has had a ton of google hits but nothing works, a thread mentioned it could be a memory leak which leads me to think maybe my RAM is acting up.
I have reported it on the mod pack forums, the minecraft forums, the java forums and literally no one has a clue what the hell is up with it.
Anyways
Error report :
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x027a9840, pid=2052, tid=3736
# JRE version: 7.0_13-b20
# Java VM: Java HotSpot(TM) Client VM (23.7-b01 mixed mode windows-x86 )
# Problematic frame:
# j is.<init>(Llq;IIZ)V+117
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x4e742000): JavaThread "Server thread" [_thread_in_Java, id=3736, stack(0x561d0000,0x56220000)]
siginfo: ExceptionCode=0xc0000005, writing address 0xab1d6215
Registers:
EAX=0x4e742000, EBX=0x45917da0, ECX=0x46be7530, EDX=0x027a340f
ESP=0x5621f7ac, EBP=0x5621f7d8, ESI=0x5621f7b0, EDI=0x5621f7f0
EIP=0x027a9840, EFLAGS=0x00010206
Top of Stack: (sp=0x5621f7ac)
0x5621f7ac: 027a340f 4328723b 061d55c0 5621f7b8
0x5621f7bc: 46be5885 5621f7f0 46be7530 00000000
0x5621f7cc: 46be5908 5621f7b0 5621f7e0 5621f818
0x5621f7dc: 027a32c7 00000001 00000014 00000040
0x5621f7ec: 0613f110 061d55c0 061d55c0 5621f7f8
0x5621f7fc: 46bac776 5621f834 46bad0f8 00000000
0x5621f80c: 46bac7f8 5621f7e0 5621f824 5621f858
0x5621f81c: 027a32c7 00000000 00000001 00000014
Instructions: (pc=0x027a9840)
0x027a9820: 85 1b 6b ff ff 8b 87 48 01 00 00 c7 87 48 01 00
0x027a9830: 00 00 00 00 00 8b 75 e4 8b 7d e8 c3 e9 dc f5 ff
0x027a9840: ff 8b 75 e4 8b 65 e0 c7 45 f8 00 00 00 00 0f 77
0x027a9850: e8 05 00 00 00 e9 4f 00 00 00 8d 44 24 04 89 75
Register to memory mapping:
EAX=0x4e742000 is a thread
EBX=0x45917da0 is an oop
{method}
- klass: {other class}
ECX=0x46be7530 is an oop
{constant pool cache}
EDX=0x027a340f is an Interpreter codelet
return entry points [0x027a2ac0, 0x027a4350] 6288 bytes
ESP=0x5621f7ac is pointing into the stack for thread: 0x4e742000
EBP=0x5621f7d8 is pointing into the stack for thread: 0x4e742000
ESI=0x5621f7b0 is pointing into the stack for thread: 0x4e742000
EDI=0x5621f7f0 is pointing into the stack for thread: 0x4e742000
Stack: [0x561d0000,0x56220000], sp=0x5621f7ac, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j ii.a(Llq;IIZ)V+46
j ii.a(Llq;)V+316
j ij.a(Llq;)V+8
j yc.a(Llq;)V+29
j in.a(Llq;)V+2
j yc.a(Ljava/util/List;)V+54
j zz.c()V+42
j im.c(II)Lzz;+214
j net.minecraft.server.MinecraftServer.e()V+158
j bdz.a(Ljava/lang/String;Ljava/lang/String;JLyn;Ljava/lang/String;)V+212
j bdz.c()Z+91
j net.minecraft.server.MinecraftServer.run()V+1
j fy.run()V+4
v ~StubRoutines::call_stub
V [jvm.dll+0x12a34a]
V [jvm.dll+0x1d968e]
V [jvm.dll+0x12a533]
V [jvm.dll+0x12a597]
V [jvm.dll+0xd306f]
V [jvm.dll+0x14a647]
V [jvm.dll+0x14a7b0]
V [jvm.dll+0x17ee89]
C [msvcr100.dll+0x5c6de] endthreadex+0x3a
C [msvcr100.dll+0x5c788] endthreadex+0xe4
C [kernel32.dll+0x13677] BaseThreadInitThunk+0x12
C [ntdll.dll+0x39f42] RtlInitializeExceptionChain+0x63
C [ntdll.dll+0x39f15] RtlInitializeExceptionChain+0x36
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x4e855400 JavaThread "Thread-35" [_thread_in_native, id=4888, stack(0x55490000,0x554e0000)]
=>0x4e742000 JavaThread "Server thread" [_thread_in_Java, id=3736, stack(0x561d0000,0x56220000)]
0x4e740c00 JavaThread "Snooper Timer" daemon [_thread_blocked, id=2344, stack(0x56140000,0x56190000)]
0x4e740400 JavaThread "LogisticsPipes Packet Compressor Server" daemon [_thread_blocked, id=2788, stack(0x55220000,0x55270000)]
0x4e73f800 JavaThread "LogisticsPipes Packet Compressor Client" daemon [_thread_blocked, id=3652, stack(0x4cb30000,0x4cb80000)]
0x4e740000 JavaThread "Thread-14" [_thread_blocked, id=2744, stack(0x4ce60000,0x4ceb0000)]
0x4e73f400 JavaThread "Thread-13" [_thread_blocked, id=4900, stack(0x4cca0000,0x4ccf0000)]
0x4e73ec00 JavaThread "Immibis Core background task" [_thread_blocked, id=3732, stack(0x53d30000,0x53d80000)]
0x4e73e800 JavaThread "Minecraft main thread" [_thread_blocked, id=1552, stack(0x4ff30000,0x4ff80000)]
0x4e0f7000 JavaThread "Timer hack thread" daemon [_thread_blocked, id=4172, stack(0x50300000,0x50350000)]
0x4e0f4c00 JavaThread "Snooper Timer" daemon [_thread_blocked, id=4364, stack(0x50030000,0x50080000)]
0x4e0f5000 JavaThread "Thread-6" [_thread_blocked, id=1640, stack(0x4dde0000,0x4de30000)]
0x4e0f6800 JavaThread "SwingWorker-pool-1-thread-6" daemon [_thread_blocked, id=3076, stack(0x50410000,0x50460000)]
0x4e0f5800 JavaThread "SwingWorker-pool-1-thread-5" daemon [_thread_blocked, id=3148, stack(0x4dd90000,0x4dde0000)]
0x4e0f4400 JavaThread "SwingWorker-pool-1-thread-4" daemon [_thread_blocked, id=4388, stack(0x4f790000,0x4f7e0000)]
0x4e0f3c00 JavaThread "DestroyJavaVM" [_thread_blocked, id=4608, stack(0x00d80000,0x00dd0000)]
0x4e0f3800 JavaThread "SwingWorker-pool-1-thread-3" daemon [_thread_blocked, id=3496, stack(0x4df30000,0x4df80000)]
0x4e0efc00 JavaThread "SwingWorker-pool-1-thread-2" daemon [_thread_blocked, id=3912, stack(0x4d7b0000,0x4d800000)]
0x4d5ffc00 JavaThread "TimerQueue" daemon [_thread_blocked, id=2652, stack(0x4e060000,0x4e0b0000)]
0x4d5a8400 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=5104, stack(0x4de80000,0x4ded0000)]
0x4d422000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=2600, stack(0x4d750000,0x4d7a0000)]
0x4d3ea000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=4308, stack(0x4d860000,0x4d8b0000)]
0x4aaacc00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=2692, stack(0x4b540000,0x4b590000)]
0x4aaac400 JavaThread "AWT-Shutdown" [_thread_blocked, id=4660, stack(0x4b160000,0x4b1b0000)]
0x4aaa9800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4924, stack(0x4b320000,0x4b370000)]
0x4a9ad800 JavaThread "Service Thread" daemon [_thread_blocked, id=3100, stack(0x4ac20000,0x4ac70000)]
0x4a9a8400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4672, stack(0x4b0a0000,0x4b0f0000)]
0x4a9a6c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=4840, stack(0x4aff0000,0x4b040000)]
0x4a9a3c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2016, stack(0x4aec0000,0x4af10000)]
0x4a94b000 JavaThread "Finalizer" daemon [_thread_blocked, id=4460, stack(0x4ae30000,0x4ae80000)]
0x4a949000 JavaThread "Reference Handler" daemon [_thread_blocked, id=3876, stack(0x4acf0000,0x4ad40000)]
Other Threads:
0x4a944800 VMThread [stack: 0x4ab30000,0x4ab80000] [id=4228]
0x4a9bf800 WatcherThread [stack: 0x4b230000,0x4b280000] [id=3672]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 47680K, used 32715K [0x047a0000, 0x07b50000, 0x19cf0000)
eden space 42432K, 64% used [0x047a0000, 0x06272ee8, 0x07110000)
from space 5248K, 100% used [0x07110000, 0x07630000, 0x07630000)
to space 5248K, 0% used [0x07630000, 0x07630000, 0x07b50000)
tenured generation total 105676K, used 70945K [0x19cf0000, 0x20423000, 0x447a0000)
the space 105676K, 67% used [0x19cf0000, 0x1e2387a0, 0x1e238800, 0x20423000)
compacting perm gen total 37376K, used 37151K [0x447a0000, 0x46c20000, 0x487a0000)
the space 37376K, 99% used [0x447a0000, 0x46be7dd0, 0x46be7e00, 0x46c20000)
No shared spaces configured.
Card table byte_map: [0x4a5a0000,0x4a7d0000] byte_map_base: 0x4a57c300
Polling page: 0x001f0000
Code Cache [0x027a0000, 0x02e40000, 0x047a0000)
total_blobs=3751 nmethods=3321 adapters=364 free_code_cache=25987Kb largest_free_block=26608960
Compilation events (10 events):
Event: 119.415 Thread 0x4a9a8400 3334 yc::F (40 bytes)
Event: 119.415 Thread 0x4a9a8400 nmethod 3334 0x02e3e248 code [0x02e3e360, 0x02e3e4a8]
Event: 119.418 Thread 0x4a9a8400 3335 aco::a (44 bytes)
Event: 119.418 Thread 0x4a9a8400 nmethod 3335 0x02e3e548 code [0x02e3e680, 0x02e3e834]
Event: 119.418 Thread 0x4a9a8400 3336 afc::a (174 bytes)
Event: 119.418 Thread 0x4a9a8400 nmethod 3336 0x02e3e948 code [0x02e3ea80, 0x02e3ecc0]
Event: 119.419 Thread 0x4a9a8400 3337 adp::a (207 bytes)
Event: 119.419 Thread 0x4a9a8400 nmethod 3337 0x02e3ef08 code [0x02e3f080, 0x02e3f344]
Event: 119.419 Thread 0x4a9a8400 3338 bw::a (40 bytes)
Event: 119.419 Thread 0x4a9a8400 nmethod 3338 0x02e3f6c8 code [0x02e3f7f0, 0x02e3f998]
GC Heap History (10 events):
Event: 114.210 GC heap before
{Heap before GC invocations=120 (full 13):
def new generation total 47680K, used 6K [0x047a0000, 0x07b50000, 0x19cf0000)
eden space 42432K, 0% used [0x047a0000, 0x047a1828, 0x07110000)
from space 5248K, 0% used [0x07110000, 0x07110000, 0x07630000)
tenured generation total 105676K, used 63405K [0x19cf0000, 0x20423000, 0x447a0000)
the space 105676K, 59% used [0x19cf0000, 0x1dadb438, 0x1dadb600, 0x20423000)
compacting perm gen total 36608K, used 36381K [0x447a0000, 0x46b60000, 0x487a0000)
the space 36608K, 99% used [0x447a0000, 0x46b27638, 0x46b27800, 0x46b60000)
Event: 114.441 GC heap after
Heap after GC invocations=121 (full 14):
def new generation total 47680K, used 0K [0x047a0000, 0x07b50000, 0x19cf0000)
eden space 42432K, 0% used [0x047a0000, 0x047a0000, 0x07110000)
the space 105676K, 59% used [0x19cf0000, 0x1dadb4d8, 0x1dadb600, 0x20423000)
Event: 114.816 GC heap before
{Heap before GC invocations=121 (full 14):
def new generation total 47680K, used 42432K [0x047a0000, 0x07b50000, 0x19cf0000)
eden space 42432K, 100% used [0x047a0000, 0x07110000, 0x07110000)
compacting perm gen total 36864K, used 36619K [0x447a0000, 0x46ba0000, 0x487a0000)
the space 36864K, 99% used [0x447a0000, 0x46b62dd0, 0x46b62e00, 0x46ba0000)
Event: 114.839 GC heap after
Heap after GC invocations=122 (full 14):
def new generation total 47680K, used 5248K [0x047a0000, 0x07b50000, 0x19cf0000)
from space 5248K, 100% used [0x07630000, 0x07b50000, 0x07b50000)
to space 5248K, 0% used [0x07110000, 0x07110000, 0x07630000)
tenured generation total 105676K, used 63472K [0x19cf0000, 0x20423000, 0x447a0000)
the space 105676K, 60% used [0x19cf0000, 0x1daec0f8, 0x1daec200, 0x20423000)
Event: 115.052 GC heap before
{Heap before GC invocations=122 (full 14):
def new generation total 47680K, used 47680K [0x047a0000, 0x07b50000, 0x19cf0000)
compacting perm gen total 36864K, used 36679K [0x447a0000, 0x46ba0000, 0x487a0000)
the space 36864K, 99% used [0x447a0000, 0x46b71ca8, 0x46b71e00, 0x46ba0000)
Event: 115.073 GC heap after
Heap after GC invocations=123 (full 14):
def new generation total 47680K, used 2534K [0x047a0000, 0x07b50000, 0x19cf0000)
from space 5248K, 48% used [0x07110000, 0x07389950, 0x07630000)
tenured generation total 105676K, used 68090K [0x19cf0000, 0x20423000, 0x447a0000)
the space 105676K, 64% used [0x19cf0000, 0x1df6eba8, 0x1df6ec00, 0x20423000)
Event: 115.259 GC heap before
{Heap before GC invocations=123 (full 14):
def new generation total 47680K, used 44966K [0x047a0000, 0x07b50000, 0x19cf0000)
compacting perm gen total 36864K, used 36731K [0x447a0000, 0x46ba0000, 0x487a0000)
the space 36864K, 99% used [0x447a0000, 0x46b7ed00, 0x46b7ee00, 0x46ba0000)
Event: 115.273 GC heap after
Heap after GC invocations=124 (full 14):
def new generation total 47680K, used 3966K [0x047a0000, 0x07b50000, 0x19cf0000)
from space 5248K, 75% used [0x07630000, 0x07a0f968, 0x07b50000)
Event: 118.883 GC heap before
{Heap before GC invocations=124 (full 14):
def new generation total 47680K, used 46398K [0x047a0000, 0x07b50000, 0x19cf0000)
compacting perm gen total 36864K, used 36833K [0x447a0000, 0x46ba0000, 0x487a0000)
the space 36864K, 99% used [0x447a0000, 0x46b98558, 0x46b98600, 0x46ba0000)
Event: 118.909 GC heap after
Heap after GC invocations=125 (full 14):
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 54.361 Thread 0x4e73e800 Threw 0x05b4cb80 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\runtime\sharedRuntime.cpp:613
Event: 62.448 Thread 0x4e73f400 Threw 0x06b52940 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 62.722 Thread 0x4e73f400 Threw 0x06a7c840 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2846
Event: 87.643 Thread 0x4e73f400 Threw 0x04f68600 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 87.643 Thread 0x4e73f400 Threw 0x04f69290 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2846
Event: 110.203 Thread 0x4e73f400 Threw 0x04f693f0 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 115.110 Thread 0x4e742000 Implicit null exception at 0x02ba7d2c to 0x02ba7f78
Event: 115.111 Thread 0x4e742000 Threw 0x050792e0 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\runtime\sharedRuntime.cpp:613
Event: 118.853 Thread 0x4e73f400 Threw 0x06f53030 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2888
Event: 118.853 Thread 0x4e73f400 Threw 0x06f53ca0 at C:\jdk7u2_32P\jdk7u13_2932_new\hotspot\src\share\vm\prims\jvm.cpp:2846
Events (10 events):
Event: 119.375 loading class 0x4e753578
Event: 119.375 loading class 0x4e753578 done
Event: 119.378 loading class 0x4e3053c8
Event: 119.378 loading class 0x4e3053c8 done
Event: 119.382 loading class 0x4e3d25c0
Event: 119.382 loading class 0x4e3d25c0 done
Event: 119.390 loading class 0x4e7825c0
Event: 119.390 loading class 0x4e7825c0 done
Event: 119.444 loading class 0x4a9f13b8
Event: 119.444 loading class 0x4a9f13b8 done
Dynamic libraries:
0x01370000 - 0x0139f000 C:\Program Files (x86)\Java\jre7\bin\java.exe
0x77e70000 - 0x77ff0000 C:\Windows\SysWOW64\ntdll.dll
0x769f0000 - 0x76b00000 C:\Windows\syswow64\kernel32.dll
0x75800000 - 0x75847000 C:\Windows\syswow64\KERNELBASE.dll
0x764d0000 - 0x76570000 C:\Windows\syswow64\ADVAPI32.dll
0x76b90000 - 0x76c3c000 C:\Windows\syswow64\msvcrt.dll
0x77130000 - 0x77149000 C:\Windows\SysWOW64\sechost.dll
0x77040000 - 0x77130000 C:\Windows\syswow64\RPCRT4.dll
0x75550000 - 0x755b0000 C:\Windows\syswow64\SspiCli.dll
0x75540000 - 0x7554c000 C:\Windows\syswow64\CRYPTBASE.dll
0x76620000 - 0x76720000 C:\Windows\syswow64\USER32.dll
0x77210000 - 0x772a0000 C:\Windows\syswow64\GDI32.dll
0x756d0000 - 0x756da000 C:\Windows\syswow64\LPK.dll
0x76730000 - 0x767ce000 C:\Windows\syswow64\USP10.dll
0x72dc0000 - 0x72f5e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_420fe3fa2b8113bd\COMCTL32.dll
0x76570000 - 0x765c7000 C:\Windows\syswow64\SHLWAPI.dll
0x76fe0000 - 0x77040000 C:\Windows\system32\IMM32.DLL
0x77300000 - 0x773cc000 C:\Windows\syswow64\MSCTF.dll
0x6b300000 - 0x6b3be000 C:\Program Files (x86)\Java\jre7\bin\msvcr100.dll
0x65e20000 - 0x6616d000 C:\Program Files (x86)\Java\jre7\bin\client\jvm.dll
0x6b470000 - 0x6b477000 C:\Windows\system32\WSOCK32.dll
0x769a0000 - 0x769d5000 C:\Windows\syswow64\WS2_32.dll
0x77e40000 - 0x77e46000 C:\Windows\syswow64\NSI.dll
0x70ec0000 - 0x70ef2000 C:\Windows\system32\WINMM.dll
0x76990000 - 0x76995000 C:\Windows\syswow64\PSAPI.DLL
0x6b430000 - 0x6b465000 C:\Program Files (x86)\Java\jre7\bin\splashscreen.dll
0x72cb0000 - 0x72d30000 C:\Windows\system32\uxtheme.dll
0x6b420000 - 0x6b42c000 C:\Program Files (x86)\Java\jre7\bin\verify.dll
0x6b400000 - 0x6b420000 C:\Program Files (x86)\Java\jre7\bin\java.dll
0x773d0000 - 0x7752c000 C:\Windows\system32\ole32.dll
0x6b3e0000 - 0x6b3f3000 C:\Program Files (x86)\Java\jre7\bin\zip.dll
0x65cd0000 - 0x65e12000 C:\Program Files (x86)\Java\jre7\bin\awt.dll
0x76b00000 - 0x76b8f000 C:\Windows\syswow64\OLEAUT32.dll
0x70c90000 - 0x70ca3000 C:\Windows\system32\DWMAPI.DLL
0x676b0000 - 0x67873000 C:\Windows\system32\d3d9.dll
0x72da0000 - 0x72da9000 C:\Windows\system32\VERSION.dll
0x6bb30000 - 0x6bb36000 C:\Windows\system32\d3d8thk.dll
0x66510000 - 0x6737e000 C:\Windows\system32\nvd3dum.dll
0x6bce0000 - 0x6bd05000 C:\Windows\system32\powrprof.dll
0x76cd0000 - 0x76e6d000 C:\Windows\syswow64\SETUPAPI.dll
0x75850000 - 0x75877000 C:\Windows\syswow64\CFGMGR32.dll
0x76fc0000 - 0x76fd2000 C:\Windows\syswow64\DEVOBJ.dll
0x75880000 - 0x764c9000 C:\Windows\syswow64\SHELL32.dll
0x6b3c0000 - 0x6b3ca000 C:\Program Files (x86)\Java\jre7\bin\management.dll
0x6b2d0000 - 0x6b2fa000 C:\Program Files (x86)\Java\jre7\bin\fontmanager.dll
0x6b2b0000 - 0x6b2c4000 C:\Program Files (x86)\Java\jre7\bin\net.dll
0x72d60000 - 0x72d9c000 C:\Windows\system32\mswsock.dll
0x6bfc0000 - 0x6bfc6000 C:\Windows\System32\wship6.dll
0x6b3d0000 - 0x6b3de000 C:\Program Files (x86)\Java\jre7\bin\nio.dll
0x6b270000 - 0x6b2a1000 C:\Program Files (x86)\Java\jre7\bin\t2k.dll
0x743c0000 - 0x743c5000 C:\Windows\System32\wshtcpip.dll
0x6c010000 - 0x6c054000 C:\Windows\system32\DNSAPI.dll
0x745d0000 - 0x745ec000 C:\Windows\system32\IPHLPAPI.DLL
0x745c0000 - 0x745c7000 C:\Windows\system32\WINNSI.DLL
0x743b0000 - 0x743b6000 C:\Windows\system32\rasadhlp.dll
0x6bfd0000 - 0x6c008000 C:\Windows\System32\fwpuclnt.dll
0x6c0e0000 - 0x6c0f6000 C:\Windows\system32\CRYPTSP.dll
0x6c0a0000 - 0x6c0db000 C:\Windows\system32\rsaenh.dll
0x72ba0000 - 0x72bb7000 C:\Windows\system32\USERENV.dll
0x73280000 - 0x7328b000 C:\Windows\system32\profapi.dll
0x74520000 - 0x74530000 C:\Windows\system32\NLAapi.dll
0x6bdc0000 - 0x6bdc8000 C:\Windows\System32\winrnr.dll
0x6bdb0000 - 0x6bdc0000 C:\Windows\system32\napinsp.dll
0x6bd90000 - 0x6bda2000 C:\Windows\system32\pnrpnsp.dll
0x6b250000 - 0x6b270000 C:\Program Files (x86)\Java\jre7\bin\sunec.dll
0x76c40000 - 0x76cc3000 C:\Windows\syswow64\CLBCatQ.DLL
0x70b90000 - 0x70c8b000 C:\Windows\system32\WindowsCodecs.dll
0x70ff0000 - 0x7103b000 C:\Windows\system32\apphelp.dll
0x6b1d0000 - 0x6b201000 C:\Windows\system32\EhStorShell.dll
0x70a50000 - 0x70b45000 C:\Windows\system32\PROPSYS.dll
0x6bf50000 - 0x6bfbf000 C:\Windows\system32\ntshrui.dll
0x6bf30000 - 0x6bf49000 C:\Windows\system32\srvcli.dll
0x6bf20000 - 0x6bf2b000 C:\Windows\system32\cscapi.dll
0x6c110000 - 0x6c11a000 C:\Windows\system32\slc.dll
0x6b220000 - 0x6b244000 C:\Program Files (x86)\Java\jre7\bin\dcpr.dll
0x6b210000 - 0x6b219000 C:\Program Files (x86)\Java\jre7\bin\sunmscapi.dll
0x756e0000 - 0x757fe000 C:\Windows\syswow64\CRYPT32.dll
0x76720000 - 0x7672c000 C:\Windows\syswow64\MSASN1.dll
0x4b370000 - 0x4b3db000 C:\Users\Stacey x\AppData\Roaming\.techniclauncher\tekkitlite\bin\natives\lwjgl.dll
0x65c00000 - 0x65cc8000 C:\Windows\system32\OPENGL32.dll
0x6b1a0000 - 0x6b1c2000 C:\Windows\system32\GLU32.dll
0x6b0b0000 - 0x6b197000 C:\Windows\system32\DDRAW.dll
0x6b0a0000 - 0x6b0a6000 C:\Windows\system32\DCIMAN32.dll
0x6b090000 - 0x6b096000 C:\Program Files (x86)\Java\jre7\bin\jawt.dll
0x61db0000 - 0x63157000 C:\Windows\system32\nvoglv32.DLL
0x76e70000 - 0x76e9d000 C:\Windows\syswow64\WINTRUST.dll
0x72a40000 - 0x72a61000 C:\Windows\system32\ntmarta.dll
0x765d0000 - 0x76615000 C:\Windows\syswow64\WLDAP32.dll
0x65ad0000 - 0x65bf9000 C:\Users\Stacey x\AppData\Roaming\.techniclauncher\tekkitlite\bin\natives\OpenAL32.dll
0x6bd10000 - 0x6bd82000 C:\Windows\system32\dsound.dll
0x70b50000 - 0x70b89000 C:\Windows\System32\MMDevApi.dll
0x72b40000 - 0x72b70000 C:\Windows\system32\wdmaud.drv
0x72b90000 - 0x72b94000 C:\Windows\system32\ksuser.dll
0x72b80000 - 0x72b87000 C:\Windows\system32\AVRT.dll
0x70a10000 - 0x70a46000 C:\Windows\system32\AUDIOSES.DLL
0x72b30000 - 0x72b38000 C:\Windows\system32\msacm32.drv
0x74540000 - 0x74554000 C:\Windows\system32\MSACM32.dll
0x72b20000 - 0x72b27000 C:\Windows\system32\midimap.dll
0x72d50000 - 0x72d5d000 C:\Windows\system32\dhcpcsvc6.DLL
0x72d30000 - 0x72d42000 C:\Windows\system32\dhcpcsvc.DLL
0x72bc0000 - 0x72cab000 C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xmx1024m
java_command: C:/Users/Stacey x/AppData/Roaming/technic-launcher.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\
USERNAME=Stacey x
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 23 Stepping 10, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7600
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, tsc
Memory: 4k page, physical 4193400k(2085500k free), swap 8384900k(5559908k free)
vm_info: Java HotSpot(TM) Client VM (23.7-b01) for windows-x86 JRE (1.7.0_13-b20), built on Jan 30 2013 10:03:58 by "java_re" with unknown MS VC++:1600
time: Tue Feb 19 19:29:33 2013
elapsed time: 119 seconds
Run Memtest86+ if you suspect that the Ram might be the cause. 2 Passes with 0 Errors is usually enough to verify it is fine. The more wall time the better though.
There is a bootable USB keymaker (and other versions) here, the one with "*NEW!*": http://www.memtest.org/#downiso
If you have to burn a CD/DVD I'd suggest UBCD instead, has lots of other useful tools and saves wasting a CD-R or DVD-R on just one: http://www.ultimatebootcd.com/
Ty you, will try it.
Java 32bit. Uninstall 32bit Java, then install 64bit.
Ehhhhh, no idea why that error log is showing that because my program files + the installer I used says 64bit....
But I redownloaded and installed any way...still same problem.
Memtest came back fine, 10 passes and no errors.
This HDD is like 5 years old, if not more, perhaps it is having write/read problems when it is trying to autosave as the game always saves on exit despite it crashing. Anyway I can test my HDD for problems? already done dskcheck and defrag, the usual hardrive maintanence.
Possibly, but did you uninstall 32bit Java?
I uninstalled the Java that was there, the only one lol. It said it was 64bit but I uninstalled it to be safe, reinstalled the new download and rebooted. Same problem.
Any idea how I can test the health of my HDD?
To note this is a pretty old rig but it has never had this problem before, its an E8400, P5QL mobo, 4GB DDR2 800 (kingston I think) with a GTX260.
OK,
Thought I would bump this, turns out the RAM is completely goosed, memtest again and it threw and a ton of errors. I just ended up buying a new mobo + CPU + RAM for the machine.
After all it's just a mess about rig, can afford to splash £200 to ease my frustration lawl.
Bugs...
