- 2 Dec 2006
Hey, well I've built this huge station now and it is very complex and it works perfectly but with one problem. I have a wooden and stone pressure plates down next to each other so that when the cart comes into a station you can sit in it as long as you want and it wont be boosted away untill after you get out and likewise a similar system on the going out cart where it wont boost off untill you get in.
Now the problem is that getting out of the cart causes it to twist so that it no longer sits flush with the track and consequently when the booster comes around it won't go anywhere. Now I see in videos people don't have this problem so what am I doing wrong? is it a consequence of a later patch perhaps?
Initially I thought I could just use a diod rail instead of a wooden pressure plate but then it just screws up the booster carts track as it appears any rail put next to a diod will snap onto it regardless of if it already had its own straight line path.
Cheers. I might get a video of my station up when I sort this out as it has taken a rediculas amount of effort and tones of red stone to make work.
). I need to now create a lever system so that I can send the cart out to all differnt directions from a control panel.
