Minecraft on Ubuntu
8 May 2011
I've just paid for and downloaded minecraft on ubuntu 11.04. However, when Iog in, the screen goes black for a few seconds, then the error below pops up. If I force update, it updates, then the same thing happens.
I'm pretty certain that java is up to date because I just downloaded it from the software center so I could open with 'sun java 6 runtime'.
--- BEGIN ERROR REPORT a1dce528 --------
Generated 7/2/11 9:52 AM
Minecraft: Minecraft Beta 1.7.2
OS: Linux (i386) version 2.6.38-8-generic
Java: 1.6.0_24, Sun Microsystems Inc.
VM: Java HotSpot(TM) Server VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
java.lang.IllegalStateException: Only one LWJGL context may be instantiated at any one time.
at org.lwjgl.opengl.Display.create(Display.java:846)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:294)
at net.minecraft.client.Minecraft.run(SourceFile:716)
at java.lang.Thread.run(Thread.java:662)
--- END ERROR REPORT 9a2f7158 ----------
Edit: I thought that maybe running an older version of minecraft might solve the problem, but after a quick google the only hits I could find required knowing someone with a previous version, or having previously had an older version installed.
Sounds like a graphics driver issue to me.
I'm trying to play on a advent 5301 which doesn't have a dedicated graphics card - I can't see how minecraft can be graphics intensive though?
It's not that it's intensive, it's more along the lines that you probably have no hardware acceleration.
Open up a terminal and type in glxinfo | grep direct and post the result here. lspci and lsmod output would be nice too.
Copied and pasted from the Terminal.
Code:
tom@tom-DIXONSXP:~$ glxinfo | grep direct
direct rendering: Yes
tom@tom-DIXONSXP:~$ lsmod
Module                  Size  Used by
cryptd                 19801  0
aes_i586               16956  1
aes_generic            38023  1 aes_i586
arc4                   12473  2
rtl8187                56206  0
mac80211              257001  1 rtl8187
cfg80211              156212  2 rtl8187,mac80211
eeprom_93cx6           12653  1 rtl8187
parport_pc             32111  0
ppdev                  12849  0
vesafb                 13449  1
binfmt_misc            13213  1
snd_hda_codec_realtek   255820  1
joydev                 17322  0
snd_hda_intel          24140  2
snd_hda_codec          90901  2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13274  1 snd_hda_codec
snd_pcm                80244  2 snd_hda_intel,snd_hda_codec
snd_seq_midi           13132  0
snd_rawmidi            25269  1 snd_seq_midi
snd_seq_midi_event     14475  1 snd_seq_midi
snd_seq                51291  2 snd_seq_midi,snd_seq_midi_event
snd_timer              28659  2 snd_pcm,snd_seq
snd_seq_device         14110  3 snd_seq_midi,snd_rawmidi,snd_seq
psmouse                73312  0
snd                    55295  13 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
serio_raw              12990  0
video                  18951  0
sis_agp                13127  1
shpchp                 32345  0
soundcore              12600  1 snd
snd_page_alloc         14073  2 snd_hda_intel,snd_pcm
lp                     13349  0
parport                36746  3 parport_pc,ppdev,lp
usbhid                 41704  0
hid                    77084  1 usbhid
usb_storage            43946  0
uas                    17676  0
sata_sis               12704  2
sis190                 22622  0
tom@tom-DIXONSXP:~$ lspci
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] SiS AGP Port (virtual PCI-to-PCI bridge)
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE] (rev 01)
00:03.0 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.1 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.3 USB Controller: Silicon Integrated Systems [SiS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02)
00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03)
00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 771/671 PCIE VGA Display Adapter (rev 10)
Minecraft still requires a half decent graphics card though... You have SIS and thats simply not very good at all.
Try picking up a second hand nVIDIA card for about a tenner and it will be many times better than that SIS 761 - Which isnt very well supported compared to nVidia in Linux.
Just to check, you did try following the instructions on the site, right?
If you run into out of memory errors, try launching it with 'java -Xmx1024M -Xms512M -cp Minecraft.jar net.minecraft.LauncherFrame'
Also, please make sure you're running the Sun JVM [i think Ubuntu uses an open source implementation by default]
That fixed problems i was having. Also - it's a laptop. Forget about upgrading the graphics.
I've never been able to understand graphics cards... any recommendations of a particular card? sorry about my stupidity...
Not stupidity if you dont know.
Ok, well the most simplest thing to consider when you are comparing graphic cards against using onboard graphics chips, is that graphics cards have their own memory, but onboard graphics chips have to grab a bit of the computers memory ( Hence, shared memory )
The shared memory has to both deal with the data for your programs and data, but it also has to display the picture on the screen too, so its going backwards and forwards all the time between these 2 and this means that both the speed of the display and the speed of the PC as a whole, suffer as a result.
With a dedicated graphics card, the CPU simply telle the graphics card what to display and the graphics card gets on with the job.
Its not quite exactly like that, but in a round about way it is.
Another way to look at it, is this :-
Lets say you are cutting your hedge but you are only allowed one clipping on the floor... You have to snip the hedge, and then brush teh clipping and then snip another bit and brush that... It takes ages doesnt it?
Well, imagine your mate alongside you with a brush! - You get on wioth the snipping and he gets on with the brushing... You will be much quicker wont you?
Thats kind of how a graphics card works.
I use the ~30 quid nvidia 210 (fanless!) and it plays minecraft pretty correctly (binary driver recommended!).
On the other hand, impossible to play with my laptop with a ATI hd5470, crashes at startup
Ok, thanks for the help, at least now I know why it won't work and can just leave it in peace. When I finally get a new laptop I'll remember to get one with a dedicated graphics card then.
Didn't see post #11 sorry, just tried
tom@tom-DIXONSXP:~/Downloads$ java -Xmx1024M -Xms512M -cp Minecraft.jar net.minecraft.LauncherFrame
Exception in thread "main" java.lang.NoClassDefFoundError: net/minecraft/LauncherFrame
Caused by: java.lang.ClassNotFoundException: net.minecraft.LauncherFrame
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
Could not find the main class: net.minecraft.LauncherFrame. Program will exit.
