Minecraft Server (Linux) - Help me with compatibility / cooler
10 Mar 2007
I'm (for now) going to work on the assumption that the system board and CPU which have been sitting in a static protected box in the wardrobe for the past 2-3 years are still okay. It's a brave assumption but if I have to shell out for a new CPU & system board later then so be it, but for now, let's find out.
CPU: Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail
Mobo: Gigabyte GA-H170M-D3H Intel H170 (Socket 1151) DDR4 Micro ATX Motherboard
1. So, would the below combine okay with the above, without any major issues? Case space going to be a problem? Any thoughts and advice are very welcome.
2. I also need advice on what's good for a CPU fan because I don't have any spare other than the stock one that came with my i7-4790k.
My basket at Overclockers UK:
Total: £294.61 (includes shipping: £11.70)
Would all fit together nicely. Also that stock cooler should be enough if you are only running a minecraft server from it.
